Can't decide between 35s or 37s
Dmopar74
Truck is leveled 2.5"
2016 6.4 ccsb
yillbs
What size rim? Stock? If so, go with 35's, 37's leveled ( IMO ) will look to squished in the wells. Open country or nitto's trail grapplers would look pretty beefy under that beast you got!
D
Dmopar74
they are the stock 18" wheels, i could run spacers i guess for now
D
Dmopar74
On second thought I would like to keep the wheels stock with no spacers as I haul a in bed camper sometimes.
Seriously considering the 315/70r18 toyo mt
Also considering 305/70/18 and 295/70/18
Will Ram 2500
Kansas City, MO
I run Cooper STT Pro's in 305/70/18 on the stock wheels with a 2 inch level. I do get some rubbing on the radius arm at full turn both ways. Nothing to worry about with the rubbing though.
Soldier of The Law
Don't forget about gears. Regarding 37's with 3.73 IMO the "juice isn't worth the squeeze". Should have 4.56 with those tires.
mondo
Columbia, Pa
2014 2wd express rcsb
Check out Thuren Fabrication for how a level looks with 38s on stock wheels. Looks good imo.
Racerx26
Like alot or just a bit?
I just put my 35's on my truck a few weeks ago, I have a 2 inch level and the rub is barely noticeable, you can't even feel it you just hear it a little from time to time at full lock
Sent from my SAMSUNG-SM-N910A using Tapatalk
D
Dmopar74
Well I'm ordering new wheels with +18 offset, will probably go with 35s due to gearing reasons
JRG18
Northern VA
6.7 CTD
Saw a truck in the parking lot yesterday that had a level on it and was running 35's. They looked great on it. 37's would have been a bit much IMO.
