Mine had a bad clunk, dealer said was normal. BS! I fixed mine, youi might check yours to see if this might be your issue. Here is a repost of my fix I posted in another topic.
UPDATE TO MY ORIGINAL FIX FOR THE CLUNK WHEN STOPPING; After about a month my clunk started too come back so on more research I pulled the driveshaft back out and removed the green grease and replaced it with C5A copper based anti seize. Its been a few months and 4k miles since and everything is still smooth as butter, no clunk at all.
Originally Posted by RodRam View Post
Seems like this topic has two different types of things going on well guys listen up my 2015 crew can 5.7 8 speed developed the clunk when you apply the brakes and stop then as you let off CLUNK well i figured it out and fixed it today, now all my stops are smooth as butter. These trucks have a two piece drive shaft on the rear section if you get down and look you will see a rubber accordion looking boot with two metal bands securing it this covers where the drive shaft is two pieces the rear one that slips inside the front one these two parts are fluted and slide together on the splines well i had a chevy Z71 that had a similar set up that did the same thing so it dawned on me this is exactly the same thing so today we pulled the back section of the shaft and removed the boot sure enough same concept as the chevy both pieces were supposed to be greased up good so when ypu stop the piece slides in smoothly and when you let off brake it slides back smoothly, what i found was dry spots and even some light rust ( only 10k on truck) also you could see where the the shaft was dry amd trying to slide it had made ruff marks on the wide splines, so we took some emory cloth sand paper and smoothed all the roughness ofd and greased the heck out of all the splines with Green Grease this stuff is slick as owl **** water proof and stays where you put it. Put shaft back together be sure to mark the two pieces so you get it back like it came apart then torque flange bolts to 85 lb and use 242 lock tight. I guarantee you this will fix that damn clunk! I hope the fix lasts a long time the chevy did. But if you had to redo it in 20-30k its not that hard to do took about a hour and a half but now that i now exactly what to do i could do it in a hour. Hope this helps some of you,
