BigDogKona
- Aug 17, 2017
- 20
- 1
- 2016
- 6.4 Hemi
I've had an issue with my 2016 Power Wagon since I bought it new. I've taken it to the dealership 3 times and they have not been able to fix it... so I'm looking for help here...
Basically, the brakes are weak. It's as if they only work at 75%
1. In panic stop situations the pedal goes to the floor and the truck stops, but not nearly as fast as one would expect.
2. Backing out of my driveway downhill, it takes full force just to stop the truck, and it rolls a few feet before it stops.
3. Anti-Lock never activates, even in panic stops... brakes couldn't lock up the tires in my wildest dreams.
4. In 4WD the brakes can't stop the truck. If I hold the gas pedal and the brakes at the same time, the engine "wins."
I had a 2006 Diesel Megacab and the brakes worked just fine... this 2016 has the worst brakes of any vehicle I have ever driven.
On the third visit to the dealer they replaced the brake booster and the check valve. This did not fix the problem.
So, I am wondering if anyone else has had a similar issue? Do you think the master cylinder could be the culprit?
Help is appreciated.
Here is a video I took after my first visit to the dealer:
https://www.dropbox.com/s/j7tf82q87hl0umg/IMG_6982.MOV?dl=0https://www.dropbox.com/s/j7tf82q87hl0umg/IMG_6982.MOV?dl=0
