BigDogKona
- Aug 17, 2017
- 20
- 1
- 2016
- 6.4 Hemi
Look again, you have hydro boost.
All of the Ram 2500s and up should have hydro-boost. I know my 2017 2500 6.4 has it. Vehicles with hydro-boost are commonly misdiagnosed.
Negative. 6.4 Hemi trucks have vacuum boosters. The vacuum line clearly comes out of the brake booster on the firewall and goes to the intake manifold. Appreciate you trying to help, but you're incorrect.
I have hydro-boost and I have a 6.4 Hemi. I'm not sure if it is the packages my truck has? I have the 22A Tradesman package, snow cheif, I have the entire build sheet...heavy duty engine cooling, 220amp alternator, etc. Maybe its just the package? I do not have another 2500 to look at right now. I have been a mechanic for 10 years, I am 100% sure I am looking at a hydroboost system under my hood. Now I am very interested of why I have have it and apparently others do not.
I always preferred alldata because I hated looking stuff up on Mitchell, situations like this is why.For work I have a program called Mitchell that I can look up every car it, it is all connected to Snap-On. Unfortunately, 2014+ heavy duty is vague on information, i'm not sure why. But they call come up with Hydro-Boost. It will not let me choose Canada made as an option. I'm not saying this because i am obviously biased, but where i work the Dodge trucks do not come in for anything but normal maintenance because they really just don't have problems, or if they do they are still under warranty. We also do state inspections, so i am going to start looking under the hoods when they come in.
If there was a problem with the booster, it would affect the power brakes drastically. The booster is what obviously provides the power by vacuum. If the pedal is very hard to push down, the booster is usually to culprit. A good way to test is: hold the brakes down as you turn the truck off, the pedal should push up a bit. Also, push the pedal down and hold when the vehicle is off, then turn it on while you are still holding the pedal, the pedal should sink.
To the dealer........"So you are telling me that a critical safety device on my truck is not working to spec. and that you are not willing to take the time to fix it under warranty. What, you want me to go ahead and drive it home? Ok, but if I get into any accident my attorney's going to have a field day with you. Please sign this statement. Thanks."
Contact the BBB about the lemon laws in your state. If they can't fix it the BBB will help you lemon it for a replacement truck.
The BBB is a useless paper lion and would be a waste of time. If the OP hasn't contacted Ram reps that visit here I'd suggest he do so. At this point he has nothing to lose.
I know the one before was called ramcares.Who are the Ram reps on the forum?
