Crazy highway vibration Brand New 2500
SpeedE55
Pompano Beach, FL/Sciota, PA
Hey all,
First time Ram owner. I just got a 2017 2500 6.7 Laramie Mega Cab. I traded in my 2012 Ford F450 6.7 for it. The Ford was also a great truck, just didn't need the towing capacity any longer and using a dually as a daily driver isn't all that practical.
The truck so far has been great other than a pretty noticeable shaking/vibration
doing 65+ mph on the highway. Anyone else ever experience this?
I have 18" factory aluminum wheels and OEM spec Firestone Transforce tires.
Anyone else heard of this issue? I hope this isn't a sign of things to come.
Steve
NewBlackDak
Hemi 6.4L
I’ve had this happen when my tires need to be balanced.
SpeedE55
SpeedE55
I certainly hadn't ruled out the tires, but given it's a brand new truck with 400 miles on it, it didn't seem likely.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Yeah loading & unloading it off of rail cars & then back onto trucks there is no telling what they may have run over. In fact it would probably **** you off to find out how they treated your new truck before it got to the dealer.
I seen a video of guys unloading new cars off of a rail car & it looked like they were going doing 40-50mph through the railcar & off the ramp out the back.
Seems like someone posted on here awhile back that he had to take his new truck back 2 or 3 times for them to finally get the tires balanced out right.
Good luck... & keep on em' until they get it right!
SpeedE55
SpeedE55
Yep, I'm aware of how vehicles can be treated. I'm in the van conversion business myself and we get new ProMasters and Transits drop shipped from the factory directly to us. Never really seen a new vehicle tire issue though. I did just look up the factory invoice on the truck and it was in inventory for 240 days before I took delivery, so depending on how long it was sitting, may have gotten slight flat spots on the tires.:cheers:
Kingsize
Mont Belvieu, Texas
I think you hit the nail on the head here. I've seen dealers have to replace new tires, yours might just be one that is in that pool. Tires aren't designed to sit like that for long periods with no movement.
HvyDuty
Perrysburg, OH
5.7L
Mine are smooth as glass since new on 18" Firestone HTs. Currently at 30k miles.
I'm rolling on OEM 18" chrome steelies though. I did notice the factory balanced them with the weights at different areas (clock positions) on the outer side of the rims at least.
Rotated myself every 8k miles or so, never been rebalanced. I run 55 PSI front, 50 PSI rear.
NewBlackDak
Hemi 6.4L
Mine were great with the HTs too, and the mileage was better to boot. When I switched to A/Ts the ride got harsher, and they’re harder to keep balanced. It was a necessity since we boondock in the desert. Nothing like being hitched up to your travel trailer, and thinking you’re going to be stuck in the sand.
Ratket
Arizona-
My money is either on tires or the wheels. One of our new fords in 2013 had a wheel that was out of round.. took the dealer a month to figure it out.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Be glad you don't own a 14 and up GM half ton. There are many complaints about vibration issues with those and they are very difficult to fix and at times GM has been buying them back. There's a several hundred page thread about it over on GM trucks.com
Hopefully your issue is not as bad to figure out. My 17 is very smooth. I'm running the oem 18" wheels and tires. 3k miles now and run front and rear at around 70psi
Jettix2
2017 Ram 2500HD
These trucks seem sensitive to tire balancing issues. My OEM 18" Transforce ATs were as smooth as glass, but I replaced them with a better tire for this coming winter (Nokian Rotiiva AT) and the dealer has balanced them TWICE and I still have a vibration. They only have an old static balancer, and they recommended I have the Discount Tire (hour away) balance them with their Hunter Roadforce balancer, which I simply haven't had time to do....
BWL
Embrace the skeptisism
BC Canada
I've had that problem a lot and it was always mud dried on the inner part of the rim. Also had guys pressure wash their wheels and knock weights off and have the same symptoms. Likely a wheel balance issue. I've also hit a pothole and had a small amount of tread seperation on my goodyear SRAS in the past which also had similar symptoms and the tire shop cleaned and balanced them without noticing. I just happened to park the right way and noticed it after a few days of banging my head against the wall trying to figure it out.
Markks
2016 Express RCSB 4X4
Pentastar
What ever you find out let us know..
My 16 1500 has had a vibration since day 1..
But it has the 20 wheels. Had a out of round wheel replaced,
and a set of Cooper's and it's decent now but still has slight
vibration in center armrest. Oh had to have Driveshaft
balanced also. But Dealer did nothing to help... Good Luck....
VLG6963
