I am in the same boat, i went to JUST ANSWER and talked to a real knowledgeable guy. here is our conversation. In our phone call which is not recorded he informed me that the CC switch wiring is bused over to the command center switch which in turn is bused to the clock spring. those part numbers are (
68163712AA, wiring between swiches)(56046375AB, Command center switch)(56046094AF Cruise control switch). He said in different instances he has seen one of those three fail. Pretty wordy but hope it helps
05 January 2019 04:51
My cruise control is not working no light no nothing. i took it to the deal who said it was the clock spring, when that didn't fix it they said it was the cc switch, that didn't fix it either. my scan tool showed a code for p1593. what is the procedure to get my cruise going. 2012 6.7 ...
view full
05 January 2019 04:54
(Posted by JustAnswer at customer's request) Hello. I would like to request the following Expert Service(s) from you: Live Phone Call.
Let me know if you need more information, or send me the service offer(s) so we can proceed.
05 January 2019 05:00
Dodge Mechanic
Hello my name is Chris and I will assist you today. I am a shop foreman at a shop foreman at a Ram dealer and have seen the wiring in the steering wheel cause this OR the steering wheel control switch on the left side cause it. The CC switch goes through that left switch. Maybe ask the dealer to check those 2 items. If you wish, I can send you the diagnostic procedure for the P1593. Let me know.
Chris
Premium Service Offer: Phone Call
Learn More
We can talk live on the phone to make it easier to get all the help you need.
Amount: $26
Connect with the Expert 24/7
By clicking “Accept this Offer,” the refundable amount above will be processed and the Expert will be credited for the original question and service.
05 January 2019 05:08
if you could send the diag procedure for it that would be awesome
05 January 2019 05:25
the last 8 of the vin cg284140
05 January 2019 05:40
Dodge Mechanic
Thanks Joe! Good talking to you tonight! The switch part number is 56046375AB and the steering wheel wiring is 68163712AA. I hope this helps, and thanks again for using just answer tonight. I will keep this session open for a few days just in case you have any follow up questions.
Chris
My goal is to provide you with excellent service. If you are satisfied, please rate me. If you have follow-up questions on this same topic, use the reply box below. To start a new conversation with me on a new topic,
request me again.
05 January 2019 07:39
Hey chris i did think of another question regarding the wiring between the clock spring and the ECM. i would like to know what the color coding is for the CC wires going through the firewall. no rush on a reply, i will be offline until monday afternoon. Again thanks for your help, and good talking to you also.
Joe
