Fbnmark
Found an aftermarket remote start on Amazon for $96 simple install (2 plugs) and works with 2 button key fob. Got the diesel specific one that has delay for the grid heater to do its thing.
Care to share a link?Found an aftermarket remote start on Amazon for $96 simple install (2 plugs) and works with 2 button key fob. Got the diesel specific one that has delay for the grid heater to do its thing.
I remote start it and let it high idle for about 10 minutes.
At that point, given a 37 - 40 degree F ambient temp, engine coolant is at about 130 degrees and the warm air has just started to emerge from the vents.
If it gets colder, I can run the Remote Start for 15 minutes, then engage the Remote Start a second time for an additional 15 minutes.
Will it go to high idle by itself after a remote start?
