NewBlackDak
- Feb 9, 2014
- 1,083
- 654
- 2014
- Hemi 6.4L
I installed it last night. Started a 6:45, and finished at 11:24. It weighs at least 3x the stock bumper. There were 2 very difficult parts on the install. First was getting the trailer connector mounted in the bumper. There is a rolled lip on the truck side of the bumper, and you're dealing with 2 6mm nylock nuts under the roll and above the connector body. Ended up using some plastic clamps to hold the plug in place, and electrical tape for the nut. Second was getting the stupid reverse sensors plugged back in. There is about 1/2 the working room behind this bumper than stock. I could not get either of the plugs to snap back into the outside sensors while mounted in the bumper. I had to uninstall the sensors to use both hands to plug them in, and reinstall them while they were plugged. I tried to do the whole thing with the spare in place, but ended up needing to drop it to attach the trailer plug harness. Should have done that earlier to get the working room.
