inthe510
- Sep 24, 2016
- 81
- 41
- SF Bay Area
- 2016 Ram 1500 Big Horn Quad Cab 4x4
- Hemi 5.7
I have a factory 5th wheel prep kit and had my bed sprayed with Line-X recently. I had removed the caps prior to installation instead of having the outer rings sprayed over. The Line-X owner told me that I would need to use something like a Dremel tool on the plastic ring retention tabs to get the caps to fit now due to added thickness of the bed and smaller circumference of the holes. I wanted to hear any other ideas before grinding away since a replacement set of caps cost about $50.
