Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
Larger Filter Available? Is M1-113 sill OK?
This is a discussion on Larger Filter Available? Is M1-113 sill OK? within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
I did my first oil change (1st one done by dealer). I go the M1 113 which all sites said ...
Like Tree1Likes
Reply
Old 01-09-2017, 03:55 PM   #1 (permalink)
Ram Year: 2016 Ram 2500 Big Horn
Engine: 6.4L
Default Larger Filter Available? Is M1-113 sill OK?
I go the M1 113 which all sites said was the proper size for my 6.4L 2500.
I compared it to the one installed by the dealer - it was much smaller - it fit but was smaller.
Mobil1 Extended Performance Oil Filter M1-113: Advance Auto Parts
This is the larger Mopar filter I took off my truck. Amazon says it does not fit my truck but this is what the dealer put in and I did not have any problems.
https://www.amazon.com/Mopar-MOPAR-0.../dp/B01FKPJ12W
If you look at the top view; you can tell that the above filter is larger - wider and longer then the M1 113. The canister and gasket on the M1 are about the same size but on the Mopar one the canister is larger then the gasket.
Anyone think there will be a problem using the M1 113? I'm towing in the southwest and will be going long distances in remote areas so I'm concerned.
I sent an email to the seller to confirm that the larger filter is OK and if it is I will be using it in the future.
Sponsored Ad
Register to remove this ad.
__________________
2016 Ram 2500 6.4L 4x4 Big Horn 4.10, anti-spin differential, Trailer Tow Mirrors, 5th wheel prep. Weather-Tech Bed liner & Mud Flaps, soft tri-fold toneau cover, NovoTech A118C Dash Camera, Mods: Wix 24578 cabin filter, tailgate LEDs, SunTeck tint front side windows
dexter is offline   Reply With Quote
Old 01-09-2017, 04:24 PM   #2 (permalink)
Engine: 6.4L
Default
OK - I got an answer from the Amazon seller - The larger filter will screw on. But the smaller one is the recommended filter. The larger one was not recommended so as to not touch a radiator hose. But there is enough room there that the larger filter will not touch the hose.
__________________
Old 01-09-2017, 05:55 PM   #3 (permalink)
Hemi395's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
Sounds like the same thing they said about the larger filter on the 5.7 will hit the electric steering rack...
__________________
Black 2013 Bighorn Crew Cab Hemi 65RFE 3.55s 4x4
Redline 5w30/Royal Purple 20-820 Filter, Redline C+, Redline Gear Oil, Diablo Trinity w/Hemifever 89 Tune, BT Catch Can, Mufflex 24, Rancho QLL, Airlift 1000, Cooper Discoverer AT3s, Mag-Hytec Trans Pan, OEM Backup Camera, Kicker Speaker Upgrade, Extang Trifecta SS, Clazzio Seat Covers, Cabin Air Filter, Weathertech Floorliners, 35% tint, Gorilla Lugs, Nasta Stainless Running Boards
Hemi395 is offline   Reply With Quote
Old 01-09-2017, 06:53 PM   #4 (permalink)
Hootbro's Avatar
Ram Year: 2015 2500
Engine: Hemi 6.4
Default
FWIW, I am running a FL-820 size filter on my 6.4 that is about 3.5" in diameter. There is at least 3/8" clearance between the filter and the coolant hose.
I think your M1-113 is smaller in diameter at about 3" and probably would fit fine. For what ever reason, they spec'd the same smaller filter for our engine as the 5.7 because of their electric steering issues but we do not have that problem. Only limitations is a coolant hose going to big on diameter and too far in length and we run into the fan and shroud.
HS-LD likes this.
__________________
Hootbro is offline   Reply With Quote
Old 01-09-2017, 08:25 PM   #5 (permalink)
Ram Year: 2015 RAM 2500 CC 4x4
Engine: 6.4 Hemi
Default
I'm using the Wix version of the larger filter. Bunch left over from my 5.7 1500. Fits fine with no interference on my 6.4 2500.
__________________
2015 Ram 2500 CC 6.4 Hemi 4x4 4.10 rear end, Gorhino W2W steps, LED rear bumper lights, Mufflex/Magnaflow, 30% front tint, Husky mats, Bull rings, front LED aux lights, Dee-Zee tailgate assist, Audiosource LC6i processor, Kicker 350.4 amp, JBL speakers, Kicker 12 sub-300 watt amp in a custom box.
reek is offline   Reply With Quote
Old 01-09-2017, 09:28 PM   #6 (permalink)
Engine: 6.4L
Default
Thanks. I think I have filter envy. The recommended filter looks really small to me.
__________________
Old 01-10-2017, 01:53 AM   #7 (permalink)
Ram Year: 2017 2500 Tradesman
Engine: 6.4L Hemi
Default
Holy smokes that filter is buried in the 1500 5.7's. I really don't think you could get a bigger one in there, as you can barely get the small one in.
Before they buried it, they all took the mopar 899's I think. On the 2500/3500 6.4's I bet the 899 size filters would probably fit. May have to see what's up next time as I still have a few of those laying around...
A bigger filter has to be better right?
__________________
2017 Ram 2500 Tradesman 6.4L Hemi, Off Road Package, 4.10 anti-spin Dif, BW 44-47 T-case
HS-LD is offline   Reply With Quote
Old 01-10-2017, 06:07 AM   #8 (permalink)
GsRAM's Avatar
Ram Year: 2017 Dodge Ram 2500
Engine: Hemi, 6.4L
Default
What is the part number for the bigger wix xp? I like wix xp, good filters in my opinion
GsRAM is offline   Reply With Quote
Old 01-10-2017, 09:50 AM   #9 (permalink)
Hemi395's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
You can get one in there it's just doesn't make for an easy removal/install. My truck is a 13 with the electric steering but it was manufactured in Dec of 2012 and came through with the larger filter from the factory.
__________________
Old 01-10-2017, 10:11 AM   #10 (permalink)
Engine: 6.4L
Default
I'm not an expert on filters but when I looked inside the two filters - larger vs recommended - the larger one seemed better constructed.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water in Sill jpl2407 Interior 6 12-19-2016 10:55 AM
4th Gen custom door sill ????? brakeblkram Interior 17 03-11-2016 11:46 AM
Door Sill Plates R/T_Fire Interior 5 01-21-2016 03:07 PM
Water pooling on door's sill Sir John Exterior 3 01-16-2015 10:09 AM
door sill guards badfish888 Interior 9 05-04-2012 10:51 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
