Left lean
cairopd1069
I know there are threads about this, but most are older threads. I found that my 2014 2500 CC 4x4 was leaning to the left. 1 3/4 inches lower on left side to be exact. Took it to the dealer and they found the left front spring appeared to be more collapsed than the right. They ordered new springs and I will update if this solves the problem. Just letting members know, in case they have the same problem.
Wandell
Cummins 6.7
1 3/4 inches is a good bit. When are they installing the new spring?
C
cairopd1069
They are supposed to install them Monday, the 27th.
C
cairopd1069
Springs were on back order, not sure when they will arrive. Will update as soon as they are installed.
Teeka
I've been waiting 3 weeks for my springs:(
C
cairopd1069
Front springs installed, still leaning, dealer ordered a pair of rear springs
RAMYOU
I heard that the left side of the truck is heavier because of the gas tank and the driver instruments that is why the rear left spring always needs to be bit taller than the right one to compensate for that. Therefore If u put an exact same height springs in the rear it tends to lean to the left.
lasse452
