Level - Do I need springs?
Andrew09HEMI
Thanks for the thorough explanation. I've also learned that without the radius arm drops, the 3" springs will bow. As bad as I hate to spend that amount of Benjamin's, I've come to the concluion, the Carli system is the way to go for me.
Once again, Andrew, thank you for the understandable explanation.
No problem! Be sure to post your results
reloaderguy
Oregon
2016 Power Wagon
We'll that's not true.
reloaderguy
Oregon
2016 Power Wagon
There's really not much to be concerned with spacers on solid axle vehicles that are 2" or less. Anything larger you should get a full spring replacement. The most important pieces when leveling are track bar and shock length. Most of us will not use the full potential of the spring compressed or extended lengths to experience bind with a spacer, again most of us. However, spacers do add pre load on the springs. For those that don't know what preload it, it's the compression of a spring at ride height. So essentially what you're doing is keeping the spring under constant load it wasn't designed for which CAN cause premature wear. That said, there's no reason one couldn't do what I'm doing which is using a HBS leveling spacer, 2" and getting Fox shocks designed for 2-3" lifts front and 1" rear. This will give you a decent level, correct shock length with the ability to swap in new springs down the road which I plan to do.
Just to note, companies will often have different views on levels/lifts and their requirements based on height due to their springs lifting at different amounts and also keep in mind they're businesses designed to make money. Just because you CAN do something, doesn't mean you SHOULD. What I mean by that is sure you can lift 3" without drop brackets and probably have no issues. But at that height, you SHOULD have radius arm drop brackets to restore factory settings. The bigger the angle on the radius arm the less your springs and shocks absorb a bump. All that energy is sent thru the radius arm into the frame and causes a jarring ride. You want radius arms and control arms in general for solid axles to be as flat as possible at ride height to ensure the most compliant ride.
Track bars will also keep your axle centered and prevent wandering and death wobble. As you lift the front axle, the factory track bar will pull the axle to the drivers side slightly. Higher you go the more it shifts. This effects your scrub radius which is the angle between front and rear axle. You want the scrub radius to be damn near perfect for obvious reasons. But you can see that lifting/leveling has a **** ton more things involved then just height. All this should be considered when you're deciding on what way you want to go.
Hope this helps some people understand the recommendations of others and why certain things are more important than others.
An aftermarket track bar will do a better job than OE but the axle will never be centered with a 3" lift. The maximum length you can adjust the track bar is 39.125" before you get metal on metal contact. Your axle will still be offset at that length.
SwollenMonkey16
Texas
We can sit here and discuss what should be upgraded or dropped all day long. All I want to know is if the 3" coils really give a 3" lift? And for those actually running the kit, is it worth the $$?
reloaderguy
Oregon
2016 Power Wagon
Thuren 3" Hemi coils will give you slightly more than 3" of lift.
thirstybob
6.7 CTD
That's what the guy at Carli told me. I'm assuming you're pic is of a 3" spring and if so do you have a full 3" of lift?
Who makes the spring? I sure don't see a bow in that spring.
What kind of set up do you have?
Andrew09HEMI
May not be bowed but it certainly isn't straight. Either way I think you'll be fine, as I mentioned correct length shocks and adjustable track bar are key here. A slightly bowed or non straight spring are the least of your worry.
reloaderguy
Oregon
2016 Power Wagon
I hate to be the bearer of bad news but non of the radius arm trucks have straight coils, factory or aftermarket. You're looking at a setup up with correct toe-in and caster and nearly perfect coils. The coil buckets always have angle to them, with or without radius arm drops.
Quick call RAM and tell them their OE coils aren't straight.
reloaderguy
Oregon
2016 Power Wagon
Full Thuren kit, 2.5" Kings, Boogies, front and rear track bar.
Andrew09HEMI
As I said it's a non issue. A slightly bowed or not perfectly straight coil isn't going to cause major issues cause of the radius when the axle flexes.
thirstybob
6.7 CTD
What's holding them in at full travel?
Andrew09HEMI
Most likely the limiting factor is the shocks or the track bar which won't allow the springs to unseat. Also the swaybar being attached will be the true limiting factor before shocks or track bar. What's holding it in place is the bumpstop and jounce
Dmopar74
It could also be the sway bar, but it will droop a fair amount. It definitely isn't the track bar, and the bumpstops and jounce bumper are beside the spring, but not connected to it at all.
Andrew09HEMI
But the track bar doesn't have that much flexibility in it is what I'd guess? Sway bar being attached is definitely a huge part but maybe it's the springs themselves. They might have enough free length unloaded to stay seated. I'm installing my level this coming weekend and I'll see.
Dmopar74
I've installed and uninstalled my level kit, the shocks, and sway bar, are the only thing preventing the axle from drooping well beyond spring length.
Andrew09HEMI
Well that's ******. Shocks should be the last thing holding em in
therapywolf
