Level or Bigger Tires Advice
ollie770
Iowa
Got a 2015 Ram 2500 CC and its stock right now. I want to improve the appearance - just would like a little more attitude and level it out. I can't drop $2000 at once on tires, wheels, and level springs. I'm fine with the chrome factory 20s. So, what will get me the most improvement/bang for the buck on looks? Will a 2" level on the front look bad with the stock 285/65R20s? Can I fit like a 295/65R20 Cooper SST Pro or AT3 without a level and not rub? Is there a different size tire to consider? Truck does light farm work, pulls trailers some, gets about 9,000 mIles a yr. Want to retain tow/payload capacity it has. Thanks!
cyclepuck
2014 2500 Mega
I'm running 285/65's on the stock 20's and stock height with no rub. Will be putting a 2" level on it eventually.
Sent from my SM-G928V using Tapatalk
Wandell
Cummins 6.7
The most common set up is a leveling kit and 35x12.50's on the OEM wheels. Of course, a slightly smaller tire will also fit.
O
ollie770
Iowa
Heres the best pic I have. It's got Ram wheel to wheel tube steps and I added the OEM clearance lights but that's it. It's only got 14000 miles on it so the tires are very good tread. I know most guys have said they won't last long - maybe I should try tout sell the tires while still good and upgrade.
