look what I found!! aFe intake!!
MADDOG
Out Exploring Arizona
Yup...found it over the weekend. Finally!!!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Like the design of this intake much more than the K&N. Says another 2 months before it is supposed to be available, but I'm definitely going to look into this one.
07MegaCabRam
Chandler, Arizona
6.7L CTD
Are you guys looking at intakes researching the actual gains on these without being tuned?
You all know you have MAP intakes right?
speed-density method of calculating engine load is not going to change with any intake you use.
Just dont want people to expect any gains as these intake can be expensive.
Ratket
Ratket
Arizona-
Full exhaust/intake/tuner- Only way to go-
loveracing1988
Clarkston, MI
The 6.4 has a mass air flow sensor.
MADDOG
8 week backorder...so now another wait begins...
i'm looking forward to getting it in the truck!
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
It do look good anyway, I would love to see what performance it give if any.
Stampederfan
Calgary, Alberta
6.4L Hemi
Did they remove it from their site? I only see the replacement filter for the 6.4.
They updated their website in the last week or so. It was on the old website but disappeared when the new website opened.
Maybe they had too many back orders and too little stock so they pulled it until they've built stock back up.
Stampederfan
Calgary, Alberta
6.4L Hemi
Weird - If you use the link at the beginning of the thread it now works and goes to the new website where you can pre-order. If you try to find it via the 'Vehicle Search' you won't.
Anyway, you can still pre-order this CAI, looks like estimated ship date is end September.
MN-Ram
MN
6.4L Hemi
I know the fuel injection system adjusts for a CAI when the truck is not tuned, but does anyone know if this would help at higher altitudes where the air is a little thinner (where non-turbo vehicles seem to have troubles) without a tune?
Stampederfan
Calgary, Alberta
6.4L Hemi
I've had them on 4 or 5 NA vehicles and they don't ever amount to much without a tune - definitely more noise if not enclosed (though this one should be pretty quiet since it is), maybe a little better throttle response, maybe a slight loss in low end and a slight gain in the mid to high RPMs.
Lots of 'maybe's' by the butt dyno. Have never dynoed any of my rigs with them but all my vehicles had tunes to take advantage of them otherwise I wouldn't have bothered.
I'm at 1,045 m (3,428 ft) here in Calgary.
MADDOG
They aren't much help without a tune but will help with throttle response at most altitudes.
It is still on backorder I see...geez...
Tray Burge
On the porch
I like it, let's face it, they mostly provide an upgraded look to the engine bay anyway. Even the Vararam which gives you dyno proven "marginal" gains are just one more part of the complete performance package that don't do much by themselves.
