Speedo adjustment for larger tires
Fanman69
Ct.
I'm wondering what folks here use for speedo adjustment when upsizing
their tires. I heard one can use a hypertech model 752503 for a 2016 2500 with 6.4. Any advice?
rgregg08
6.4 hemi
AEV's pro cal is not available to purchase unless you buy their lift. Superchip's Flash Cal isn't compatible with 2017's and the 6.4 (i called), not sure about 2016's my guess is negative. Hypertech is on my to do list to call and ask.
Im in the same boat, waiting to put on a set of 35's on my 17 Power Wagon till a calibrator comes out.
Fanman69
Fanman69
Ct.
I already emailed Hypertech last week. They said it was not compatible.
I'm thinking they are saying that because they don't have the full 6.4 upgrade yet.
A guy on another forum said he used the hypertech on his 2016 w/ 6.4 without any issues. It was however the diesel unit, but worked for the tire size.
reloaderguy
Oregon
2016 Power Wagon
I have a ProCal, it works well for the price.
mohemipar
Michigan
2017 Laramie
6.4 Hemi, 4.10's
AEV was supposed to be releasing their ProCal for the HD Rams for stand alone purchase last month or so, but they went silent on it. Hopefully they will get around to it soon. I would like to pick one of those up.
reloaderguy
Oregon
2016 Power Wagon
Some of the AEV dealers sell the ProCal on the DL.
rgregg08
6.4 hemi
I emailed the one shop that I believe everyone was gettting them from. They said no dice unless I was getting the truck serviced there. I'm in Texas they are in the northeast........................rattttttsssss. If you know somewhere else please shoot me a PM.
rgregg08
6.4 hemi
I emailed Hypertech today as well, same response "nothing offered for that vehicle at this time".
Fanman69
Fanman69
Ct.
Update on the Hypertech:
Picked up the Hypertech 752503 model yesterday. It is for the diesel, but worked without issue on my 6.4
I updated the unit via internet before using it on my truck, worked great.
One note, my tires are 37" on paper, but Nitto specs say 36.77". Unit increments are .25", so I used 36.75. Speedo was off +2MPH. Speedo was off -5MPH before programming. I adjusted the programmer to 36" even, and speedo is dead nuts with GPS.
So it does work, just a little tweaking to dial it in.
BTW.. In order to use the unit on another vehicle, you have to reset back to stock on the original vehicle. So basically, one unit for each truck.
Cheers.
rgregg08
6.4 hemi
Cheers.
Thanks for the update. Wondering why they say it won't work but does??? Yep on the tweaking. I would chalk measure my jeep tires to get it dialed in. I assume your truck drives different now, shifts points in line, etc now?
RainDesert
ID
Cheers.
Thanks for the info and report.
SwollenMonkey16
Texas
if you run the same size tire as stock but just wider adding about 11-13 pounds per tire will it have the same affect as running a larger size tire diameter wise?
R.L.K.
Bristol , Tn.
The Simple answer is No.
Speedometer being off is all diameter of the tire not width or weight .
A larger diameter tire travels further per revolution , hence the difference in speed .
Fanman69
Fanman69
Ct.
I agree, however tire manufacturer's sizes are never equal to what the actual size is. My 37's are actually 36.77" in diameter per manufacturer's website. Doesn't sound like much, but .75" change on my truck computer equaled 2MPH difference. I also think their size is based on tire with full pressure, but no weight of vehicle. I'm guess that could change the final OD as well.
ocwill1
Severn, MD
5.7 eTorque
Here are my .02.. I went from stock 20's, 2016 2500 to 305/70/18's and did a little test. set cruise to 70, and had waze running on phone and it bounced between 70 and 71... I am assuming because the computer has the stock pressure at 65 and 80, and I am running at 50/45, that may have something to do with it.. But, moral of story, save myself $230 by not having to buy the hypertech...
Ratket
Arizona-
Skip the hypertech and get a diablo with a. Custom tune??
Fanman69
Fanman69
Ct.
I doubt one can find a diablo for $200.
I think the 6.4 has plenty of ponies as is anyway.
Was looking for a speedo calibration tool for a reasonable price.
If I get the need for speed, I have other toys for that.
Fanman69
Fanman69
Ct.
Speed is accurate, which is always nice. Odometer is keeping correct miles traveled. I'd like to say the tranny shift points improved, but can't be certain as the tires when on the same day as the adjustments were made.
radikio
