Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
Suspension popping/clunking
This is a discussion on Suspension popping/clunking within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
I have it installed for just over a year now. Never had issues. Started popping about two weeks now. Especially ...
Reply
Old 01-10-2017, 12:22 AM   #11 (permalink)
Ram Year: 2017
Engine: 6.4 Hemi
Default
I have it installed for just over a year now. Never had issues. Started popping about two weeks now. Especially when it's cold.
Sent from my SM-G935V using Tapatalk
Sponsored Ad
Register to remove this ad.
__________________
2015 Ram 2500 CC 6.4 Outdoorsman 4.10's (OLD)
2017 Ram 2500 MC 6.4 BigHorn Sport 4.10's (NEW)
zeddy is offline   Reply With Quote
Old 01-10-2017, 12:28 PM   #12 (permalink)
PCT's Avatar
PCT
Ram Year: 2013 Ram
Engine: 4.7
Default
I'm assuming the spacer fits ontop of the coil tower/assembly. Is there a chance that the assembly is slightly compromised and the cold exasperated it? Cause 2.5 inches isn't a lot of lift, yeah it's about the max you want to go before you deal with geometry, unless the new HD trucks are different
Sent from my SAMSUNG-SM-T817A using Tapatalk
__________________
2013 Ram 1500 4.7, Bilstien 5100 2.5, Mevotech UCA,Nitto Terra Grappler, Flowmaster Delta 40, Idatalink Receiver, Dual 10inch Kicker subs. K&N Air Filter, Airlift 1000, Debadged, Deezee Grill Guard
PCT is offline   Reply With Quote
Old 01-10-2017, 12:54 PM   #13 (permalink)
Ram Year: 2017
Engine: 6.4 Hemi
Default
Coils are straight, nothing loose. the spacer actually bolts onto the spring bucket (if that's what it's called). Dealer said they checked and tightened everything. they said i altered the geometry of the truck thus causing the popping/clunk (they won't fix a known/common problem with the HD's because i have a leveling kit, and can't fix other issues). I really dont know anymore, as much i love my truck, i think i'm done with this truck and ram....people warned me about dodge, horrible customer service, don't take care of their product. Took the benefit of the doubt. should of stuck with nissan. Nissan always stuck behind their product and always takes care of their customer.
just a little frustrated....
__________________
Old 01-10-2017, 02:09 PM   #14 (permalink)
BIGWHITE16's Avatar
Ram Year: 2016 Ram 2500 Tradesman
Engine: 6.4L HEMI
Default
I have a 2.5" pro comp coil spacer. No popping. No clunking.
__________________
http://i459.photobucket.com/albums/q...9/bigwhite.jpg
2016 RAM 2500 Tradesman
20x9 Mayhem
35 Toyo A/T
Pro Comp Level
Magnaflow Exhaust/Res Delete
Spray-In Bedliner
RECON cab/license plate
Stubby 3" Antenna
NEXT...Iron Cross Front /Rear Road Armor
BIGWHITE16 is offline   Reply With Quote
Old 01-10-2017, 02:14 PM   #15 (permalink)
Ram Year: 2017
Engine: 6.4 Hemi
Default
I have mine for over year and never had a single noise come from the suspension. There's a guy who posted a video of the body mount popping. Sounds the exact same.... Started a few weeks ago. The symptoms are right on the money when it comes to the body mount TSB, to the "T".
__________________
Old 01-17-2017, 01:31 AM   #16 (permalink)
PCT's Avatar
PCT
Ram Year: 2013 Ram
Engine: 4.7
Default
Sorry haven't been much help...
Sorry for ignorance, TSB as in dealer fix, or something else?
__________________
Old 01-17-2017, 01:42 AM   #17 (permalink)
Ram Year: 2017
Engine: 6.4 Hemi
Default
Can't figure it out. I even tightened the body mounts and same thing. Every other bolt/nut nice and tight.
__________________
Old 01-17-2017, 01:48 AM   #18 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
Doesn't matter what brand it is.. unless u are buddy buddy with the dealership and they installed the aftermarket parts - This is a prime example of what happens. Unfortunately you will most likely have to pull the spacers and get the truck to mimic the noise with one of their techs in it. Other than that they are just gonna keep blaming the after market parts. And again let me stress that issue right there is not just a " Dodge " issue- My local ford dealership is the same way.. I suggest you start making friends with their service writer- Or maybe reach out to a after market shop for help- I like rough country - But they won't be able to help you at all- Maybe look to a more " Dosge aftermarket shop- Or company that deals with these trucks-
Dodge off road . Com-
Cjc off road . Com-
Try describing your issue and see what they have heard/ Noticed?
I know my truck pops on the driver side when I over extend the suspension-
I am not sure how your springs could be perfectly straight because in order to get that 2" or 2.5" you compressed those springers by adding a spacer-
Maybe toss up some pics for us? -
Maybe try a different dealer?
If the dealer is the same one you bought the truck from - Start hunting you will shop else where..
__________________
2014 Ram 2500 mega cab Big Horn 6.4 4x4 3.73's Factory 20's wrapped in a 33" maximum steel/ Factory cab length running boards/ UnderCover Flex Tonneau cover/de badged/tinted over factory tint.
Ratket is offline   Reply With Quote
Old 01-18-2017, 09:35 AM   #19 (permalink)
Ram Year: 2017
Engine: 6.4 Hemi
Default
Yeah, the coils are bowed alittle.
I've been looking around and some torquing the body mounts down. I torqued them down about another 1/2 a turn. Today's the second day and haven't heard anything yet (knock on wood). I knew it had to do with the body mounts.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
rear end clunking Axioner General Discussion 9 02-26-2016 12:20 AM
Help with the Popping slicktherick3 Engine & Performance 9 07-10-2015 10:27 PM
Popping out of 4wd StarfishFarms Exterior 0 02-04-2014 04:39 PM
Popping/clunking from steering box fla crkr 1 ton General Discussion 2 01-07-2014 07:25 PM
4x4 clunking Luke(MI) Tech Info 4 06-24-2011 06:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
