loveracing1988
- Jul 4, 2013
- 3,505
- 913
- Clarkston, MI
- 2020
- 6.7 Cummins
I definitely hear you about the wind resistance. My dad has a 7x4 slight v-nose enclosed trailer. Empty it weights 2300 pounds, I get around 9.5 to 10 pulling it, which is the same as when I pulled a 8800 pound mini excavator.I'd like a CTD for 6 months. The other 6 months the 6.4 is wonderful. Cruising the backroads off the beaten path, the 6.4's lighter feeling steering over the CTD really shines, uses fuel, but is much more nimble.
I've found the longer & steadier the pull, the better the towing mileage. This past spring we took a 1465 mile round trip to Lake Powell and back pulling our 6000# TT all loaded up. Hand calc'd 9.3 for the trip keeping speeds between 65-70. Went from 7200' to 3700' and back including all the mountainous terrain in between. So I'd say your observation towing the rental are right in there.
Now, pulling my snowmachine trailer with a 28" tall deck, front unloading ramps upright, loaded with my Polaris Ranger with half front and full rear glass, load is 3000# at most, is like pulling a frikkin' steel parachute!! The 6.4 will pull it at whatever speed, but the drag makes it work! 7-8 mpg is the best I can expect when driving 65. When I have a headwind, I expect 5-6 pulling this setup. Its so light, but there I so much air resistance. I pulled this same setup with a 2013 CTD and managed 10.5 mpg. So, my point is, if I was going to be primarily pulling a 5th wheel with a lot of air resistance, CTD all the way!
The comparison to a 2013 ctd is good but not very impressive. I figured it would be better honestly. Maybe I'm just expecting too much, I know you can't really put a number to just how much better it probably pulled the trailer but I would still expect a little bit better.
