Will Ram 2500
- Sep 29, 2015
- 271
- 138
- Kansas City, MO
- 2015
- Hemi 6.4
Did you put the adjustable bar on the front to recenter ypur front diff or the steering box fix to keep it from the ole wobble?
Sent from my SM-N930V using Tapatalk
That 305/70 is basically a 35x12, right?
No. Wanted to keep cost down. So far it's great. These trucks look massive with that extra height on the front.
Leans back a little towing around 2k lbs.I want those tires. I mam go a little smaller so I don't have to level. I tow and haul daily so I don't want to be,leaning back.
Looks sweet. I am considering this exact setup. What brand level is that? Did you readjust your TPMS or are you just living with the light on? I want that size but I have a 2016 and you cant adjust the Pressure setting so I'm stuck with 80psi tires or leaving the light on which I hate.
I haul around a small landscaping trailer too. Have you noticed any difference pulling it with the larger tires? Do you have 4.10s or 3.73s? I have 3.73s and was worried I wouldn't like it if I went up to a 35 inch tire. Amazing how much nicer that truck looks than mine with just small change.
