Tires and level kit are on
Dmopar74
So since you have 35's, do you think you'd fit 37s without a problem?
Juvenator93
I have a 2 1/2" on 35s. I think 37s would rub166b73ab979953c139407c98d2492232.jpg61bfa40ffc7a50b9ea14e70e85583ae2.jpg
danh63
Yes. I didn't like the stock wheels until I put mud tires on them. The right tire can make all the difference!
'That is true, I had the stock ones with 37x12.5 on my old dodge. Love those tires. Is there a lot of road noise with those?
Will Ram 2500
Will Ram 2500
Kansas City, MO
I notice more noise when coasting at lower speeds as it's slowing down. They make a sound like a bad differential at those speeds. Other than that, it's just a light hum.
bradh_24054
Demi 6.4
Good looking truck! One of the best looking trucks on here IMO!!! I love the stock look with beefy tires! Awesome! Exactly the look I want! I have one question, Do they rub at all with the leveling kit?? I have level on mine and with stock tires It doesn't look like there is much room at full lock!
Will Ram 2500
Will Ram 2500
Kansas City, MO
Thank you! Granite is the best color next to Maximum Steel on those trucks. I like how the black of the tinted windows and the black tool box accent the gray. I was wanting some OEM black wheels they put on the blackout package, but they are priced way to high on ebay as you see the same wheels sit for sale for months with no drop in price and no one will negotiate much at all, so I gave up on that. They do rub a little on the big lower arm in the area towards the back at full lock going backwards. Seems like backing up when turned right is worse...prob because of the lug direction when turned that way. Can feel just a little vibration. That would rub regardless of a level kit or not. A wheel spacer would correct that. But, it's been my favorite truck by far and my first Ram.
bradh_24054
Demi 6.4
How much of a spacer do you think it would need to prevent the rubbing?? I guess it depends on the offset of the wheel. I don't have the factory 18" wheel you have I have the factory 18" wheel that comes on the SLT's and I don't know if they have they same offset as your's does! I don't know how to figure it out unless I might be able to talk to the dealership!
Will Ram 2500
Will Ram 2500
Kansas City, MO
Would be the same offset. Really, it's such a small rub, it's not worth doing anything with it. These are like +53 or 56...something like that. From what I've read, +18 is the best for this size tire.
Chad E Robinson
Tennessee
6.7 cummins
Do you have any rubbing going. I have the same truck other than the motor. I pull a 40 travel trailer and I definitely cant have rubbing when I'm backing that thing. Your truck looks good I would like to do mine like this.
Ratket
Arizona-
How to fit 37”s -
Also if you go with a “ spacer kit” look at hell bent steel they include the proper length bilstien shocks so you don’t have to use a shock extension.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
Truck looks great and amazed how much bigger than stock it looks. Now tuck your tow mirrors back down since there is no trailer behind you. :supergay::signs8::signs8:
olyelr
Kewadin MI
Truck looks great!
Well now that you have had the tires a few years, how have you liked them and how have they held up for you?
POINTMAN380
Rogers, AR
I wish I didn't have to tow so much. Im so tempted to level mine for 35's. Truck looks sick man
olyelr
Kewadin MI
Just install bags and a wireless one air kit. Perfect setup for a leveled tow rig.
