Tpms
shipmasta
Santa Cruz, Ca
6.7l
I purchased a 2015 2500. Truck came lifted on 37 x 13.5 R20s. Tires are Toyo Open Country MT. The tires say to inflate to 65psi cold, but the truck says 80psi (for the rear). As a result my TPMS light stays on and shows both rear tires under inflated.
What are people doing about this? Do I just ignore the light? Can it be reprogramed by the dealer?
I do not want to over inflate the tires.
Thanks.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Yup... just got to put up with the light. From everything I have been told anything after 2014 cannot be reprogramed. I have a 2016 & the dealer tried but FCA changed things so it can't be changed.
We need one of those master hackers to fix it for us!:naughty:
07MegaCabRam
Chandler, Arizona
6.7L CTD
Thankfully I got mine changed when I went to 35" tires before the WiTech 2 Upgrade.
There is a guy here in Arizona that can adjust them. He charges $50 and does it in 5 minutes. Think you'll have to find someone in your area that has the necessary tools to do it.
RAM_Designs
Rockwall, TX
6.4L Hemi
Gotta put up with the light. I have tires that are 65psi max also, but air them at 50psi...just gotta deal with the light.
Iron Outlaw
Seems like someone could make some kind of dummy sensors to put on. I don't know how tpms works but we used to run o2 sensor simulators when we would delete emissions and install longtubes on my old fbodies. Seems like they could make something similar to disable rpms all together
reek
Sacramento
if that could be done, the maker would make some good money. atleast til the watcher shut it down....
S
shipmasta
Santa Cruz, Ca
6.7l
Thanks guys. I will try to have what The Hulk suggested done, if not I will live with it. The light itself does not bother me, its the fact that every time I start the truck it resets to the TPMS page.
Odin
Arizona aka HELL
Hemi 6.4L
I'm I'm AZ and I need this done. Lol. Where's this guy at?
zogg
Southern Illinois
2018 Ram Express Quad Cab
Yep...I have the same issue with my 2016. The dealer tried to reset it but no good....
I'm set at 45 pounds all around and have to reset the flashing light every time I start the dammm truck. For $50K, they should have supplied the truck with a guy to do it for me hahahaha
articsilber323
2500 ctd
i found out it can be done with an autel scanner, some people have bought there own to do it with the same steps at the witech
i have an autel in maryland and was able to do it to my own 2016 2500
running 45f 40r
lanceb1b
So how much does it cost for the cheapest model that will reprogram the TPMS?
running 45f 40r
07MegaCabRam
Chandler, Arizona
6.7L CTD
Facebook,
Look for ACDC (AZ Cummins Diesel Crew) and search for Ryan Ellis.
BIGWHITE16
TEXAS
2016 Ram 2500 Tradesman
6.4L HEMI
thankfully i got mine changed when i went to 35" tires before the witech 2 upgrade.
There is a guy here in arizona that can adjust them. He charges $50 and does it in 5 minutes. Think you'll have to find someone in your area that has the necessary tools to do it.
i need someone in houston!
BIGWHITE16
TEXAS
6.4L HEMI
Same Here.
BIGWHITE16
TEXAS
6.4L HEMI
Houston Autel!!!
running 45f 40r
Can ANYONE locate someone with an AUTEL in Houston so I don't have to fork over 1200 to buy one?
BPMPVET
Cummins 6.7
BIGWHITE16 just watched me do the procedure on FaceTime. I think we're working out a way for me to send it to him so we both don't get hosed. I'll probably be able to do that for more members in the future. Anyone in Arizona, feel free to message me.
1Popeye
