This light? If so it has happened to me twice so far. Both times require the truck to be shut off and door opened and then restarted to clear it.
That light is the for the ESC which is apart of the same system that controls the BLD(Brake Lock Differential). That may be the reason why you said you have never noticed the BLD kicking in because their is a fault in the system. Just a thought.
Hmmmm I thought that light was the low tire pressure indicator?This light? If so it has happened to me twice so far. Both times require the truck to be shut off and door opened and then restarted to clear it.
