Transmission Pan with plug & what transmission do I have?
dexter
Banned
Anyone have a recommendation for a transmission pan with a plug - adding a couple of quarts of fluid would be OK too. But I really just want a simple installation and that it can accommodate the temperature sensor.
The other thing is - how do I confirm which transmission I have?
66RFE or 68RFE
I'm guessing I have the 66 because I have 4.10 rear gears.
Thanks
derag2
6.4 hemi
What truck and motor? If it's gas it's a 66 and diesel is the 68
tjfdesmo
AZ
Mag-Hytec has been around for a long time. I think the 68RFE pan will fit the 66RFE. You can verify that with them.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
I am running the DORMAN 265-817 pan with drain plug on my 66RFE and with a Fumoto Valve for a 14mmX1.0 thread. This unit will also fit the 68RFE.
Dorman Products - 265-817
Their fitment guide stops at 2010 but it fits my 2015 with no issues. The pan is actually pretty good quality and would recommend using the MOPAR OEM sealant for the pan and be sure to torque the bolts to factory specs.
opie
Does the 66rfe have a serviceable filter?
Sent from a field
D
dexter
Banned
That looks good.
I think there is a sensor in the transmission pan (I may be wrong) does this pan acomminate it or am I wrong?
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
That looks good.
There is no sensor on the pan itself. With the exception of having the threaded **** and drain plug, it is a dimensional one for one swap with the factory pan. You will not lose or gain any capacity using it. All you have transfer over is magnet puck from the inside of the factory pan to the new pan.
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
Sent from a field
Yes it does, two. A semi-flat inlet screen filter with pickup tube, and a spin on can filter that rests internal inside the pan.
opie
Thanks.
Sent from a field
D
dexter
Banned
That's fantastic.
The most difficult part of changing the transmission fluid is draining the fluid and it dripping all over the place.
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
That's fantastic.
Yeah, once I had the replacement pan, I sacrificed the old pan by slowly drilling a drain hole in it for fluid removal. Saved on the splashing.
