Trying to decide; 2500 Mega Cab 4X4 or 3500 Mega Cab 4X4
Redfish 504
Diesel
Need Help: would like to hear from someone with some knowledge of ride between 2013 & 2014 2500 4x4 mega cab and 2014 3500SA 4x4 mega cab. Is there a major difference between the two. I understand the towing differences but really I am concerned on the ride as prices are not much if any different between 2500 & 3500SA. Ready to purchase just would like to hear from first hand knowledge.
Thanks in advance for any replies
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
I went through this same decision process three months ago, 2500 mega cab vs 3500 mega cab??? Price not really alot different, gas or diesel, unless you go with the dually axle and the Aisin Transmission, price added for those are about $4000extra. The information that helped me make my decision was what my intended use of the truck was going to be, in my case towing a fifth wheel is the final use, the 2500 has the same towing trating as the 3500, actually a couple of hundred pound higher but close enough to same they are the same, so what other difference are there? payload 2500=2200lbs in the bed 3500=4400lbs in the bed, as most fifths in the size I'm looking at weigh in around 2000lbs tongue weight, I didn't what to max out the payload right at the start. We choose the 3500 laramie CTD. It is supposed to arrive today or tomorrow, can't wait to get it. Ride wise I drove both and found the 3500 slightly harsher in ride but nothing I wasn't willing to live with. We didn't get the new air ride suspension for two reasons, 1 wasn't available yet 2- not sure if I wanted a system never used before, I like new products to have ayear or two use to work out the bugs prior to me owing them. I suggest you drive both like I did and decide for yourself. Hope this helped a little.
W.C.
Gainesville, GA
6.7 I-6
the payload on the 3500 vs 2500 - is that with the Dually rear, or do you get 4400 lbs. with the single rear wheel on the 3500 - If so, what makes up the difference?
I just got a 2500 Cummins Mega and looking into a 5th wheel as well - wondering if I could add what the 3500 has to the rear on my truck?
Thanks all for your help,
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
If you don't NEED the 2500/3500 payload, check out the 1500.
The crewcab interior dimensions actually are larger than the megacab in almost all areas. Basically, more room.
loveracing1988
Clarkston, MI
The 3500 has a completely different suspension setup than the 2500, so no you can't really add anything.
