What exhaust for 6.4 hemi
SETEX 6.4
Port Neches, TX
Single FM 50 HD replaced the original with short straight pipe in front with no resonator turned down right behind the axle.
Sent from my SAMSUNG-SM-G891A using Tapatalk
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
I have a Magnaflow Cat Back. 19200. Many people also go with the Mufflex which is also a Magnaflow muffler.
Moab_Rockstar
Lake Orion, MI
5.9L
I have the 3" flowmaster "dual" cat-back exhaust. 50 series muffler. Has a good idle and rumble during drive without being too obnoxious. Sounds good at higher RPM. The drone during cruise is pretty minor. I still liked the sound of my '04 5.7L 1500 better. I did true duals on that one with an x-pipe. The mufflers were 2.5" Dynomax Race bullet style. A lot more highway drone though.
Flowmaster at Jegs: 389-817709
Broke pilot
Conroe, TX
6.4L
Just chop the old muffler off and put a magnaglow or something straight through with minimal restrictions. Flows sound good but they don't necessarily flow well.
That being said, I have a single in dual out 40 series on the mega dumped at the axle cus I had it laying in the shop.
No need to spend a bunch of money on the exhaust unless you're going headers. The factory tubing is plenty big enough to breathe on the 6.4.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
I went Magnaflow but I think that it's subjective.
MADDOG
Not RamForum Staff
I put a Magnaflow on mine and removed the resonator. Sounded good.
Calvinm119
I added a Flowmaster Super 40 and deleted the resonator. The exhaust dumps right behind the rear axle. Sounds mean but does have a moderate drone but hey, its a v8 truck.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I did the Flowmaster 50HD duel in & duel out. Sounds really good at idle & part throttle. It is a little too raspy for my liking when you get into it. I have had flowmaster 50 series on other trucks & it sounded great so I think it might have something to do with the duel in/out. I was just trying to save some money with one muffler & someone told me this set up would also act as an X-pipe.
jtlp8335
Ozark, MO
This is the setup I'm considering also. It looks like it replaces the stock resonator with a MF res--do you have much drone?
theviking
Yes, it does replace the stock resonator with one hidden on the other side of the axle. While it does use their biggest muffler it's still much more aggressive then stock. I also have full length headers so mine's louder then most. IMO, if you like the typical Magnaflow sound, it's a nice option. I get a lot of compliments.
G. Mcpherson
Yacolt, Wa.
There is some drone . I don't use the regular drive with the Eco mode. In that you will have considerate drone when going into Eco. I use the Manual mode shifting into 6th gear. Much better sound and minimal drone to me. I purchased mine through Hot Exhaust.com. Best pricing that I found with their discount code.
wgreggking
rural Arizona
2017 4x4 offroad
Here's a clip from flowmasters site, for a replacement 3.5" pipe dia., muffler that fits 6.4 listed to 2015, but I don't see any reason it would not fit my 2017. Was pondering mufflex/magnaflow, but considering adding a little pipe and the flowmaster 853548
Super 40 Muffler 409S - 3.50 Offset In / 3.50 Offset Out - Aggressive Sound. Looks like they kept the resonator on.any thought's?
http://www.flowmastermufflers.com/s...&category=Street Mufflers&category2&category3
ronheater70
Do you guys notice any seat of the pants change in acceleration? just curious, I figure it's mostly a sound improvement and count you'll ever feel any gains unless you went with a full exhaust, headers etc..
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
it's a 7,000 lb vehicle and you're talking single digit horsepower gains, if that. there's not going to be any noticeable gains, this is all about sound and marginal fuel economy.
ronheater70
Thanks IRSmart, thats what i figured..it would need to compliment other improvements for there to be a noticeable gain, but boy the sound sure is nice...Im still on the fence about my gears .. I still want gears but then the guys in my thread about towing pretty much dashed my hope..L
