zeddy
Icon Suspension - Icon Suspension 2.5 Inch Lift Coil Springs, Front, Stock - 2.5 Inch Lift Range, Black, Pair of 2 - 214200 | 4WheelParts.com
2017 Ram Mega Cab 6.4. I want to go with a spring leveling kit this time vs. the block. I know carli and thuren are excellent but they only have 2inch or 3inch. For some reason, I feel the 2inch is not enough and the 3 is going to be a tad much. I know, .5inch isn't much but that's when my pickyness comes into play. My 2015 Ram had a 2.5 block and I absolutely loved the way it sat.
4Wheelparts tells me this^^^^this Icon 2.5 inch won't fit on my 2017 Ram. I call ********. isn't the same? Why wouldn't it fit. If for some reason, it doesn't would the carli or thuren 2inch spring for the diesel sit alittle higher? I know the the springs for the diesel is a little different because of the weight of the truck.
thanks in advance.
thanks in advance.
