- Aug 25, 2012
- 784
- 696
- Southern Illinois
- 2018 Ram Express Quad Cab
- Hemi 5.7
I just finished installing a set of four rancho 9000 adjustable shocks on my 2016 2500 4x4. The rough ride was a real issue for me at age 70, so I needed to do something short of trading for a 1500....
The fronts were pretty easy except for the top shock nut. It's pretty tight getting a wrench on that top nut, and without a ratcheting box end wrench it would be tough to get off. Also, with only 8500 miles on the truck that is always garaged, the shock shaft didn't spin and the nut came right off....nice working on a clean new truck.
The backs were a different story. The bottom bolt was a snap....the top is a pain. The upper stud and top half of the shock goes through the frame, and after 40 minutes, I decided the only was to even get to that top nut was to remove the wheel well liner....not hard, just a pita....
Again, the top nut came right off, but if it was rusted, I'm not sure how to get it off....really tight. Tightening the top nut was a pain...I had to hold the shock shaft with an 8 mm open end wrench while tightening the top lock nut....
Anyway, it's all done and back together...took about three hours, but I'm old and getting up and down for tools takes longer than it used to...haha
Took it for about a quick four mile test run on a state road....what a big difference. The small jarring jabs to the spine are about gone, but the ride is still firm, but better. I set the front shocks on the third adjustment and the rear on the second.
I'm pretty happy for now but it is pouring, so I'll do a longer run tomorrow and do a follow up post.
I bought them on Amazon.com, for $380, and got a $100 mail in rebate. We will see if it's truly worth it.....
