Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Photo Gallery Forum > Member Trucks
Member Trucks
2003 Ram build thread
This is a discussion on 2003 Ram build thread within the Member Trucks forums, part of the Dodge Ram Photo Gallery Forum category!
Starting a thread showing the progress of my first truck. I bought it used for only 5k knowing I needed ...
Like Tree71Likes
Reply
Old 10-30-2016, 04:49 PM   #1 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default 2003 Ram build thread
Starting a thread showing the progress of my first truck. I bought it used for only 5k knowing I needed to put in some work on it. I have a lot of mod plans for the truck as money is available and I'm enjoying working on it in my spare time.
Getting it off the lot, first thing done was taking off the completely rusted out exhaust and replacing it with a summit racing cat back
Debadged and removed the pin striping
New audio system
Cranked the torsion bars up for a 2" level
Removed the step bars
Rebuilt the heads due to a head gasket leak from the previous owners neglect. Got a valve job done and new pushrods
New front bumper, headlights, fog lights and light bar. I sanded down both bumpers and applied a spray on bed liner to them. I was really happy with the results
Plastidipped the grill
5% tint on the back window and 20% on the front windows
New bolt on flares
Future plans are adding shorty headers, CAI, a tuner, and rims and tires. One thing at a time!
Sponsored Ad
Register to remove this ad.
chrisp2493 is offline   Reply With Quote
Old 10-31-2016, 03:11 AM   #2 (permalink)
Ram Year: 2005
Engine: 4.7 Magnum V8
Default
nice bro. you getting black rims?
sposer17 is offline   Reply With Quote
Old 10-31-2016, 06:47 AM   #3 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Hopefully next summer, that's the plan at least
Old 11-15-2016, 02:32 PM   #4 (permalink)
akennedyusmc's Avatar
Ram Year: 2008
Engine: Hemi 5.7
Default
I like the look of the Bedliner bumper! Thinking about doing the same on my truck
akennedyusmc is offline   Reply With Quote
Old 11-15-2016, 09:24 PM   #5 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Thank you! I used Defender-Pro epoxy bedliner, it was a cheaper spray on alternative to Line-x and I was really happy with the results. It was very easy to spray after roughing up the bumper finish and so far it looks tough as nails.
Old 11-15-2016, 09:27 PM   #6 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Well I am starting the long tube header project tonight. I got a set of the pacesetter headers.
I spent about 2 hours removing the factory paint with a torch and wire brush and then painted them with 3 coats of VHT Header paint. Tomorrow I'll start the removal of the manifolds and get the new ones in. Any tips or tricks from anyone with experience with this install would be greatly appreciated!
Old 11-18-2016, 07:33 PM   #7 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Well two more days of work and I finally got the headers all done. The install was fairly simple. The pacesetters fit right in no problem, I was frankly surprised how easily the fit up on the driver side.
I read somewhere on here that you had to grind off a mounting tab on the passenger side of the transmission. I did that, but I may have taken Alittle too much off
As far as I can tell, it's just the bell housing so there isn't any pressure or fluid inside there, so I just filled the gap in with silicone to keep out water and debris.
The next problem I ran into was my idea of trying to reuse the old y pipe. I tried to figure out how to fab my own new one, but I figured raw material would cost me over $150 and the pacesetter y pipe was only $230. So I made a run to summit racing again to pick up the y pipe and get pack to work. It fit very well and saved me a lot of time and hassle.
Well instead of getting new cats I decided to do a cat delete. I had to add a bung in the y pipe for the downstream o2 sensor since none was provided. I went with the non fouler trick, so instead of welding a threaded bung on, I just drilled a hole in the pipe and welded one of the non foulers in. I just screwed the other non fouler into that and called it good.
The next issue was the fuel and egr relief valve lines on the driver side. They were practically on top of the exhaust collector. I put the fuel line in the next slot up on the bracket on the frame. I found some heat shield wrap at AutoZone and covered the various lines in it. Then I took a piece of sheet metal and bent it over and around the pipe and shot a few screws into the frame to hold it. Hopefully that helps.
Lastly, since I didn't have cats on the driver side originally, (I'm assuming because I have the 4x4) I had to plug the o2 hole on the driver side header. I went to napa and they had a plug for it for $9.
It definitely changed the exhaust note, gave it just a touch of a chug to it. It sounds pretty good with my summit racing rat back. I haven't driven it much today yet, but it did seem Alittle snappier on the throttle. Can't wait to see if it's any better on the on ramps or not. I'm definitely happy to get rid of the exhaust leak on the driver side and the cracked header on the other side!
Old 11-20-2016, 04:42 PM   #8 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
Well after driving it for a few days, I've noticed a problem with major exhaust drone at 60-70 mph (1600-1900 rpms). I have a summit racing muffler on right now, will changing out the muffler to something else help? I've had my eye on the spintech pro street 9000 anyways, so maybe this is my excuse to get it
Old 11-22-2016, 08:06 PM   #9 (permalink)
chrisp2493's Avatar
Ram Year: 2003
Engine: 5.7 Hemi
Default
I did the TMR delete today after reading up on it in forums. I've never heard of it before, but I tried it and was surprised at the outcome. WOT pulls feels so much more aggressive and the shift is way quicker. I guess that's the only perk of an 03 ram
Old 11-22-2016, 08:21 PM   #10 (permalink)
jaycabral27's Avatar
Ram Year: 2015
Engine: 5.7
Default
Awesome work your doing. Keep it up, love looking at the progress!
THETANK and destroyaYO like this.
__________________
Jaycabral27's Build Thread
jaycabral27 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Detail is done! PICS, PICS, PICS!!! cheapbeater Photos & Videos 18 02-26-2014 03:48 PM
for those of you that wanted pics go to albumsand look at pics lawman dj General Discussions 0 12-27-2013 05:04 PM
Any Pics out there? Stagman Exterior 7 11-13-2011 01:36 AM
RamForum.com Central IL GTG - May 29, 2011 - PICS!! (lots and lots of pics!!) 0212353 Photos & Videos 73 06-06-2011 12:24 PM
Srt-10 hood done pics pics pics ramhunter9 Member Trucks 71 07-09-2010 05:18 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
