derekp
- Mar 10, 2015
- 2,131
- 1,789
- Buda, Tx
- 2007
- 1990 5.9 Cummins
What light bar and mounts did you go with? Can you post up some close up pics of the mounting as I'm fixing to go through this and I don't want a half *** looking setup.
I bought my brackets off of eBay from a company called jc kustoms out of Texas. The cree light bar came from california, also off of ebay.
The brackets are placed behind the weather stripping on the door frame. They sent self tapping screws to mount the brackets but I just don't trust those. I took my headliner out a little bit and put bolts through two of the brackets holes. A total pain in the ass to do but worth it. There are tiny screws that hold the weather stripping in place. I took one out on each side and used the hole for reference for lining it up. I drilled bigger holes and put the bolts through. I self tapped the ground on the side and ran a wire through to hook up. Not hard just tedious.
