That should be pretty easy as far as coverage goes for sure. Chat with someone over at DYC.com their support is great and came in really handy both before and during. Ask them what size kit to go with and then add on an extra can of final color. I went with the "extra large" and only added 1 can of blue... I wish I had added at least 1 can of the base color AND 1 can of the blue. Always better to have some extra, I just ordered another gallon of each for repairs. Also, i bought the advanced turbine sprayer, a little more money but again seemed worth it.
I used cardboard to test my spray pattern and distance with, I also shot on that cardboard every time I refilled my paint cup and that definetly helped, it always seemed to spatter for the first trigger pull when reloading the cup. Tape, tape, tape and tape. Don't leave anything to chance, if you don't want it painted make sure its covered up well. The top that i used on the bottom of the window trim didn't stick well and now I need to go after it with dip dissolve.
Practice your "plan of attack" before actually spraying. Yes, look like a fool and walk around the car with the sprayer pretending to spray. It'll give you a good idea of problem areas or spots that you may have to turn the sprayer a certain way to fully cover. Be quick on pulling the tape after the last coat, using another set of hands can really help but if you are doing it solo I would say once you hit the side of the vehicle you're on pull the tape. Last thing if you have someone else there with you to help have them the turbine air hose, it is a bit clunky and the last thing you want it to do is to get stuck, pull off, OR hit/rub the car.
Roll down your windows, wrap your plastic inside and then bring the windows back up. I just rolled mine down today and found some over spray on the edge of the glass. Any other questions feel free to ask.
