My 04 Ram 1500 Mod thread
HeavyD
Medicine Hat, Alberta - Canada
4.7 SOHC 5 SP Auto
This is my 2004 Dodge Ram 1500 Quad Cab 2wd 6.5' box.
Pics will be the way I got.
Took the Front seats out to clean it properly.
I have already Taken off the Cheap Hood scoop off.
Had the Oil changed to Full Penzoil Synthertic.
Ordered:
1 - New Aftermarket Headlights, Taillights & third brake light.
2 - Chrome door, tailgate handle & Fuel door covers
3 - Single DIN Installation Dash Kit, since the aftermarket radio was flopping around - & will be using My Alpine deck from my last car.
Other pics will come as things are done.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Here is a list of stuff I already have done or bought locally for the truck
Tailgate handle Chrome cover – $32.92
Chrome molding & black touch up paint - $32.55
Oil Change - $134.41
Exhaust Tip & 3M scratch remover & Bosch wipers- $118.60
Antifreeze – $35.47
On Monday March 2 - going to Nation Transmission to have them replace the tranny rear seal - also Filter Flush & fill - just over $300
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
And stuff I ordered online
Headlights + Tailights + third Brake light – C $246.13
Radio Din – C $25.16
Chrome Plated 4 Door Handle Covers Kit – C $42.76
Chrome Plated Mirror Covers - C $51.15
CHROME FUEL TANK DOOR COVER - C $29.38
NGK-ZFR6F-11G Spark Plugs – C $29.21
Pair Transponder Chip Ignition Truck Key Replacement Blanks – C $26.36
Chrome Fender Trim 02-08 Dodge Ram – C $115.3
Pics will come as stuff is installed
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
My drivers seat is worn out, I was looking for better used ones.
Had a thought today, took the drivers seat off the tracks & put the pass seat on drivers tracks & installed. Other than the back tilt handle & side skirt, they are interchangeable.
So don't need seats for now, & can put money to getting the leaks fixed.
EWC88
Southern NJ
Good job with the seat. I have that issue with mine but my fabric is also torn so looking at getting it all replaced. Keep posting your progress!
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Oh ya, tomorrow should be a good day for me. It should be at least 9*C.
So plan to fix the power steering hoses (and flush), if I have time - fix the tranny line going to the cooler.
Then if I have time - see why both front door outer handles are loose or broken.
Also this week yet I will be installing the Chrome handle & mirror covers, exhaust tip.
I got the handle & mirror covers today.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Ok yesterday fixed the power steering & tranny lines.
then went to the car wash to wash them areas.
pics from today showing where leaks were.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
I cleaned the rims with 0000 steel wool - look way better - but going to have to clean again, next time im taking the rims off.
Also today I added some chrome
EWC88
Southern NJ
Looking good man! Take some Polish to the rims as well get them to sparkle.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
I need to finish cleaning first, & I was planning to use autosol which is a metal polish.
Also did buy 3m scratch remover & after that maybe a complete buffing.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
I got all the chrome trim attached properly, the 2-way tape that the chrome came with says 3m but don't think it is, or just lower grade.
tipnitty
Oklahoma
Need to buff that paint, it's swirled to no end!
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
So far today I got my Flashpaq & updated it.
Still waiting for more stuff in the mail, so not putting on truck yet.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Wasn't going to play with the programmer today, but the other deliveries are not going to be here today.
put it to the 87 tune.
the installed my radio - only one speaker works properly - put them on the list.
then found more amp wires & stuff, they had double wires for everything. So I pulled out the lower parts where the ashtray & cup holders(broken).
So lots of cleaning to do.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
pics of lower dash apart, then cleaned & reinstalled.
Also installed the economy xs program & reinstalled the pass seat.
EWC88
Southern NJ
Looking good, I want to remove my center seat and do a console so bad.
HeavyD
HeavyD
4.7 SOHC 5 SP Auto
Got presents today, going to install all if I can.
& yes that's a 6x9 speaker box there for reference to the size of boxes.
boxes inside boxes!
corumba
