Rebuilt 5.7L Hemi Startup
RonJon '06
Southern Minnesota
This is the first start after rebuilding the 5.7 in my '06. You can hear the exact moment the oil reaches the top of the engine. It only took 6-7 seconds, but it seemed like forever from where I was sitting. :uhoh2:
5.7 Hemi Startup - Youtube
charonblk07
Calgary, Ab
F1-A forged 349ci
Vid's set to private, and you didn't prime the oil system first?
RonJon '06
RonJon '06
Southern Minnesota
Fixed it.
No, I didn't prime it. I was planning on pulling the Relay before I started it the first time but just realized that my '06 doesn't have one. The only fuse I found that deactivated the fuel pump also deactivated the ignition/starter. I thought about pulling the injectors but thought that the assembly lube would be enough.
