CS5 tips
johnnysart
Albuquerque
5.9 Magnum
Heres one I use all the time. Its special past in cs5.
Its very simple technique that I use all the time.
First I use my polygonal lasso tool-
Then under edit I use copy-
Then under edit- "special past" and "past in place"
And after unselecting the other layer you can see your selection is there-
You can also duplicate the same layer in the same location under layer then duplicate layer.
I'll try and post up tips but you are all welcome to post tips also- so don't be shy.
johnnysart
johnnysart
Albuquerque
5.9 Magnum
Just incase your wondering - "why would I use special past" heres another demo why-
original pic-
Here is I used special past, I also I cropped out the shadows-
Heres my duplicate layer and I erased some of the shadows to create a smoother transition-
And here I have both layers-
So now I can copy this truck and past it here-
johnnysart
johnnysart
Albuquerque
5.9 Magnum
And yes I did remove the dent.
johnnysart
johnnysart
Albuquerque
5.9 Magnum
I lowered the percentage of the eraser tool to 35% then 20%
johnnysart
johnnysart
Albuquerque
5.9 Magnum
Thank you and I hope it helps. I know I use this "ALLOT".
