I know this is an older post, but I'm kind of a Photoshop guy. I'll help you out.
More than likely the reason someone didnt reply is the lift, and there's another car sitting behind your truck. The pole on the right, the line where the grass meets your driveway, etc. Things like that are pretty challenging to make a 'realistic' Photoshop come out like you might want it.
If you can post up a good 3/4 view of your truck parked with not a lot of things around it, trees are ok just things difficult to duplicate I'll see what I can do for you.
Photoshop is usually done in layers. For example two identical pictures, one on top of the other but with the lower half cut off the top one.. you could lift the truck. Make sense? You can move each layer around as you need to to get it lifted or lowered.. lowering is much easier because these things dont matter so much. lifting a truck you can see more behind it, in the wheel wells, etc. In your picture it would be challenging add more of that car sitting behind your truck.
A good shot in an open field, or at a lake front maybe? Maybe I'm no pro but I'm willing to give it a shot.
