You can see the "sun spot" in the picture. The screen is completely lit with full color, I've just always had to use the hard buttons to use it. It worked perfectly for me when loaded my hemifever tune on and did all my logging.Can you describe the touchscreen issue with the tuner? Does it not work at all where the sun distorted the display?
I have this exact setup in my 2016 Big Horn. They DO NOT raise the rear of the truck past stock height when inflated. They just prevent sag when a load is in the bed or tounge weight is added at the hitch.Do these make the rear sit higher if not loaded down?
Sent from my XT1635-01 using Tapatalk
Did you notice a rougher ride?I have this exact setup in my 2016 Big Horn. They DO NOT raise the rear of the truck past stock height when inflated. They just prevent sag when a load is in the bed or tounge weight is added at the hitch.
Sent from my Z982 using Tapatalk
