Metalizer
At full pressure (25 psi) you might see an inch. However if your not towing nor have a load you would set the psi @ 10 which gives hardly any lift.Do these make the rear sit higher if not loaded down?
Sent from my XT1635-01 using Tapatalk
Sent from my SAMSUNG-SM-G891A using Tapatalk
