- Jul 14, 2010
- 25,443
- 3,908
- 2021 TRX
- Hellcat
I will check the bag when I get home and let you know if there is a pn on it.You wouldn't happen to have a part number for those?
I was looking for that a few months ago and never could find it.
PN: 68044460AA
My experience.....If you call the dealer, they will tell you that they only come with the steps and aren't available otherwise. However, if you call the dealer, they can order the above part number. I called one of the local dealers in my area with the part number and they actually had it in stock. Cost me about $30.
I should mention that the above kit only includes the rivnuts and corresponding bolts. It does not include the set tool or the smaller bolts that run through the pinch weld and screw into the step bracket.
For the tool, it was in my kit. The tool is 1 bolt, 1 lock washer and 2 nuts. You can see the bolt in his install kit above.
What does the install tool look like?
Is it something you can work around using other common tools?
In the picture I posted in the first post it is in the ziplock bag with the paper that says installation instructions. It's a bolt, a washer, and a nut. In post 11 the hulk says there are two nuts and a lock washer
