- Jul 17, 2012
- 9,421
- 4,702
- Conroe, TX
- 2014 Ram 1500
- Whipple Supercharged 422" Hemi
This is a Ground Force 2/3 lowering kit for the 09-up Ram 1500 4 door 4wd trucks. Included in this kit are the Ground Force 2" drop springs already mounted on a pair of factory struts to make for an easy install. You also get the rear 3" drop springs, a pair of shorter Belltech rear swaybar end links a new set of Belltech rear bumpstops, as well as the Airlift 60824 Helper bags...I kept the hardware for the bags, so this is just the bags and spacers as shown in the picture. You will need to purchase the lines and fittings to use these bags on your truck. I do not have the Ground Force rear shocks that initially came with the kit, but I have been running this on my truck for the last 16,000 miles with stock rear shocks and no issues whatsoever. Price is $450 if picked up local or $500 shipped in the lower 48. New, this kit is $845 without the swaybar end links or airbags. Below is the picture of the kit and how it looked on my truck...
