No worries if the buyer takes the radio to his local dealer , they can give them the security code in less than 3 min.
They will need the vin from the truck it came from to get the code
Requires a compass module , a 3 wire harness and a dealer flashed code CV2.Does this require anything else to make the compass work? A Bluetooth mirror would be required as well correct?
No !Would this work on a 2012?
Sent from hell via TapATalk
Bought above radio. You don't know part numbers to madule and harness do you. Can you find them on ebay.
