WTS: LED low beams, high beams, and fogs
Status
Not open for further replies.
Dubstep Shep
Houston
2014 R/T
SOLD!!!
Selling a full kit for LED low beams, high beams, and foglights for the 4th gen rams with the projector headlights.
This kit includes three sets of bulbs, two sets of PWM adaptors, and one set of resistors. The PWM adapters are for use on the low and high beams, and the resistors are for use on the low beams.
All this together would normally retail for $675. Asking $300 shipped OBO plus PP fees.
I only used them for a few weeks.
Originally I bought them because I thought they would fit inside my headlight and not require me to cut the dust cap at all, like with HID kits. Unfortunately, I got the "bulb out" message when I installed the lights with the PWM module. The manufacturer told me that isn't uncommon and I needed the resistors. I went ahead and completed the kit, but I didn't want to cut my dust caps so I'm just selling it all.
Low beam kit:
9012 LED Headlight Kit | 9012 LED Upgrade
PWM Module:
HID Kit PWM HID kit Module | HID kit canceller | Anti-flicker module
Resistor Kit:
9005/9006/9012 HID kit Low Beam error Fix
High beam kit:
9005 LED Headlight Kit | 9005 LED Upgrade
Fog light kit:
9006 LED Headlight Kit | 9006 LED Upgrade
These things are pretty dang bright:
almst791
How long have these been in use in your truck?
Dubstep Shep
Dubstep Shep
Houston
2014 R/T
Good question, I completely forgot to add that to the OP.
12sportmc
NC
Why don't you want to cut your dust caps? Seems like such waste of lights. Lol. GLWS.
Dubstep Shep
Dubstep Shep
Houston
2014 R/T
Because I don't? I just don't want to have dust caps with holes in them later on if I decide to go back to OEM lights.
14-RAMMER
Maryland
Hemi. 5.7
How's the difference between HIDs and the LEDs?
Dubstep Shep
Dubstep Shep
Houston
2014 R/T
I've never had HID's but my LED's are bright as holy ****
I can't say for sure as I haven't had HIDs in this truck. The LEDs are bright as hell though, that's for sure.
Other than that, there's no warm up time on a LED bulb, so you can hit your brights and they come straight on. The LEDs also last a lot longer, according to the manufacturer these are good for 50,000 hours.
And these are for the projector style stock ram headlights?
Correct.
dhows31
Mississippi
Would you separate them as I would just want the highs
Rescue52
I have a 2016 Ram Express Quad Cab, will these fit my truck?
_____________________________________
Light travels faster than sound,
that why some people appear bright until they open their mouth!
Dubstep Shep
Dubstep Shep
Houston
2014 R/T
I'm only willing to split them up if they're all spoken for.
I'm not sure. I know 2015 trucks have other issues with the lights that aren't a problem on the 2014s, which is what mine is.
ill take the lows
If you want the lows and dhows31 wants the highs then I just need someone for the fogs.
dhows31
Mississippi
I'm out sorry I bought some morimoto projectors last night.
whetrick1
How much for the fog lights and will they work on a 2016 Ram
Dubstep Shep
Dubstep Shep
Houston
2014 R/T
I would imagine they would work on a 2016, but I don't know for sure.
Right now I'm trying to sell as a set. If I can get someone fully committed for each set then I'll split them up.
Status
