North Dallas Maintenance Shop Recommendation?
AzRamLover
Not from the area - can any folks recommend any shops in the 635 & Dallas North Tollway area?
Need to get a laundry list of things done for the 60K.
Inspect CV/Universal joints
Inspect front suspension & tie rod ends
Inspect front & rear axle surfaces
Tighten parking brake
Change engine oil SAE 5W-20 Mopar, Pennzoil, or Shell Helix
Change engine oil filter Mopar
Change transfer case fluid Mopar BW44-44
Change front axle fluid SAE 75W-85 Mopar GL-5 Synthetic Axle Lubricant
Change rear axle fluid SAE 75W-140 Mopar Synthetic Gear Lubricant PLUS Mopar Limited Slip Additive MS-10111
Change brake fluid & flush brake lines through each brake caliper Mopar DOT 3 fluid
Change power steering fluid Mopar ATF+4 Automatic Transmission Fluid
A
AzRamLover
FWIW, I ended up going to Auto Pros in Addison, TX and they were excellent.
Highly recommended.
They did not pay me or give me anything to write this.
