My Ram Runner
RamRacer
Ok so its not a full on Ram Runner but it does have Radflo 2.5 coil overs :)
Pretty happy about it so far! Im looking for Lights for the Bumper, any suggestions on an affordable set up?
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Looks good! I like it, I have a couple, well, one now as the 12" started retaining moisture. I'm sending it back and looking at mounting a 30" on my sport bumper, not fond of drilling holes in my bumper though. I hear a lot of guys saying good things about the Rough Country lights so you might check them out.
RamRacer
RamRacer
I will check them out.. I just drove form portland to Boise last weekend at night and with out my fogs it sucks... i might get some of these KC long range lights.. I kinda like the Old school KC Look anyway
Amazon.com: KC HiLiTES 150 Apollo Pro 6" 100w Spot Beam Light System: Automotive
Peattie
Las Vegas
I'm going to end up doing the same but probably with kings. Looks good man. What upper arms did you go with?
SilverStreak88
Houston, Texas
5.7 Eco Gasser
RamRacer
RamRacer
Peattie i bought a set from someone on here they were advertised a year ago, they were the kore stage 1 arms advertised as a kit but i didnt realise the kit came with different high angle cv joints.. so i was advised not to put them on with out them.. so stock right now. i have bora spacers on it.
Peattie
Las Vegas
You should be fine without them. Theres a few people who have done a similar build w/o the new cv's. If you keep the sway bar on I don't see it making a huge difference in the cv angle.
How do you like the radflo coils? I'm going to end up doing a similar build but not sure if I should go radflo or kings. And I'll probably get total chaos uppers if the local shop doesn't want to build me some.
RamRacer
RamRacer
This might sound dumb but what is the purpose for switching to the different upper A arms?
Peattie
Las Vegas
Ball joints are supposed to be limited on how my the can travel. Uniballs have a little more movement allowing the shock to compress and stuff better.
Switching to a uniball upper gives you about 1" more in travel. With uniball uppers and a new coil over you should have about 11" of travel up front.
Not 100% needed, but better performance wise.
RamRacer
RamRacer
might install just for better looks.. :roflsquared: i just wouldnt want to damage anything
Peattie
Las Vegas
They do look better lol. If you plan on putting the truck to work in the dirt IMO I would buy them just to have the piece of mind. Judging by some of the trucks that need to replace ball joints after lifting a truck thats mostly on the street, I don't think the OEM ones are strong enough for the desert.
But since nobody has really tested the oem uppers its hard to tell. I plan on going that route because the uniball is better than a ball joint for off roading, and after market arms are a little beefier.
O.R.T.
Wessyyydddeee
Note to self, move to Idaho, finish building out truck, have fun wheel'n and mountain bik'n.
Freaking Moto guys have all the nice toys. ;)
RedFlameRam
