I have a 2012 Ram 1500 Laramie 5.7L I replaced the Throttle Body with a BBK 90mm unit. After doing so, I did the idle relearn procedure that came with the instructions. Started the truck everything was fine, next day while driving down the road the Check Engine light came on for a P0507 - higher then expected Idle. Cleared it and in about 20-30 miles the same thing. The idle seems normal on the tach. I connected my scan tool to it and the desired idle is 585 rpm and actual idle fluctuates between 620-660 rpm. I did an idle relearn using the scan tool and did not help, the light comes on every 20-30 miles after clearing it.
Whats weird is the conditions for setting this code is 200 rpm difference at idle for longer then 30 seconds - That doesn't happen, and every time the light comes on it's when I'm driving down the highway, not even idling. I checked for vacuum leaks and nothing, and the tach seems to be in the same place it always was, nothing excessive.
Anyone have any issues like this.
