Hey guys thanks for the responses. Unfortunately, no punching, no arrest, and still, no 4 wheel drive.
Yes, I mean when I'm on a patch of ice or my truck is stuck in the snow (frequent), when in ANY 4WD, I figured at least one front should spin. After sending it to a dealer for computer updates (the only reason I brought it to a dealer), a second transfer case motor and a wiring harness, I still do not have front tire power on the ground.
Ironically, with the truck in the air and the tires off the ground, when the truck is put in any 4wd mode, the fronts do spin. On the ground, not so much. When stuck on snow or ice and the gas pedal is mashed, the backs spin but nothing on either tire up front.
Since I can hear the actuator, uh, actuate when I put it in 4WD, I originally replaced the transfer case motor. I was never really sure if I fixed it because spring came and I forgot all about it. This winter however, the problem reared its ugly head again. I brought it to a dealer to see if it was a computer problem. They installed 3 computer updates, changed the transfer case motor again (they said the new one was melted) and the wiring harness (also melted) and I still have the same problem. It is back at the dealer right now, and they are saying its the clutch in the transfer case. I disagree and still think there is an electrical problem going to the little motor. When I have the truck on my lift off the ground, I had my girlfriend move the 4wd knob from 2wd to 4wdauto to 4wdlock to 4wd low. I removed the transfer case motor physically from the case but left it plugged in. The motor never moved when she switched between any of the 4wd modes.
Can someone with a 2011 1500 please confirm that the transfer case motor should move when you move the 4wd knob? Or at least confirm that you hear two sounds (actuator AND case motor) when you put in 4WD? I had someone do it with a 2010, but I guess it's a slightly different animal.
Thanks in advance.
dunney
