highcountry69
- Jan 27, 2014
- 7
- 2
- 2003
- 5.7 hemi
Hello everyone. I've got a brake problem on my 2012 2500 4x4 crewcab that the dealer could not( or would not) diagnose, and I'm hoping someone on here can help. About 3 weeks ago I started hearing a loud whistling/humming noise as I was driving. It sounded like it was coming from the rear of the truck. The noise was loudest at 35 mph, and faded out completely at higher speeds. Upon initial search, I felt the rotors and all four were extremely hot. I pulled the rear tires and with the rear end off the ground, truck in neutral, I could barely spin the rotors. It took all I had just to move them a couple inches. This was equal on both sides, did not do the same test with the front at that time, though I should have, as they were equally as hot. I checked the fluid level, it was good. At this point, I took it to the dealer because it is still under warranty. After two weeks the dealer wants to change out the rotors and the parking brake shoes which of course are not covered on the warranty because they are considered "wear" parts. To me this was a bogus diagnosis and I declined the service because I knew I did not need those parts. The problem seems to me to be with the fluid pressure as at least two, if not four of the brakes are dragging at the same time. Wouldn't this lean towards the components that control fluid pressure distribution? Anyway, I'm out a diagnostic fee( which I believe I should not have had to pay, but did) and a $600/mo truck that I can't drive. I am at a loss as what to do next, as apparently the "pros" at the dealer can't help. I'm pretty good with a wrench, so I can fix it myself if I can just find the root of the problem. Has anyone on here heard of or had this problem before, and how'd you fix it? TIA
