2013 Preview
garner
Harker Heights, TX
The front end is pretty much like what they did on the 06-08, just angled the bottom of the grille and different headlights. Well this one has new bumpers, but yeah you get what I mean
Big Boi
S. Fla
Is the upper bumper cap the same as the 09-12's?
If so, all one would need is the bumper, fogs (unless they used the same ones), and mesh grill...
The grill shell looks about the same
shibby927
The Great State of Iowa
I read that the grille is taller now, I'm assuming that would need the new bumper and cap to fit the new grille. Sounds like a pretty expensive venture to me. I think I'll just swap my 2011 RAM out for a 2014 or 15 when they come to market. I've also been reading that this new RAM is going to have some new fuel saving technology. Shaved some weight from various places including the frame by using more high strength steel.
Car and Driver has a pretty damned good break down of all the info on the 2013 RAM.
http://www.caranddriver.com/news/2013-ram-1500-photos-and-info-car-news
blackout11
alpharetts GA
2011 R/T
Not sure about replacing the grill think it has shutters or something
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i like that center stack, and the cluster. do NOT like the "shifter". ick.
LED tails! nice! except for the chrome on them? is that chrome trim on the tails?!?!
quietpeen
2021 TRX
Hellcat
i don't hate the look of the new center stack, but i like what i have better. What they did mimics what the new chargers center stack looks like. I would like the bigger touch screen though
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Its the 8.4" version.
So, in reading.............crew cab with the 6'4" bed. new stack. keyless start / stop.
I think I'm going to sell the body lift. No more mods on the '10. I may not like the headlights..........but I know a guy that can change that. :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Woah! Electronic power steering and suspension has 5 adjustable heights??? BADASS!
But only 395 hp... Meh not much difference engine wise.
Tapatalk'in
8 speed!
quietpeen
2021 TRX
Hellcat
this is what was in that article, so i would think the 2014 hemi will get the 8 speed
Both V-8s hook up to a standard six-speed automatic, but the Hemi will receive a version of the eight-speed as an option sometime early next year.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no 8 speed yet for the hemi.
so you are gonna get a crew with the 6'4 bed?
thats what I would be after.
Hemi V-8s buyers can specify the same eight-speed automatic mated to the Pentastar V-6
late option I guess
few things I have seen that peaked interest:
previously optional quad halogen headlights are now standard across the 1500 line, as are LED taillights. Also new is a headlight option that includes LED indicators and side markers
Next is a new, four-corner air suspension, adapted from the one available on the Jeep Grand Cherokee. It has five ride-height settings: Normal, Aero, Off-Road 1, Off-Road 2, and Park. The Aero setting kicks in automatically at speed, lowering the truck 1.1 inches from Normal. Off-Road 1 raises the truck 1.2 inches, and Off-Road 2 brings a full 2.0-inch rise over the baseline Normal position. Park mode lowers the ride height 2.0 inches below Normal, giving occupants a lower step-in height and also providing easier access to the bed. Any of the five ride-height settings can be manually selected via dash-mounted buttons or the key fob from outside the vehicle. The air suspenders also perform load-leveling tricks, helping to maintain a steady ride height front and rear even when the truck is loaded up with cargo or a trailer.
Trupiano
Registered User
6.7L CTD
That's badass... But for anyone trying to lift or lower they're trucks, this could be a BIG PROBLEM!
I'm thinking if the truck try's to level itself your gonna have to deactivate that... Which would require a tuner, which you won't be able to get.
Plus an air bag suspension is alot more $$$ than a simple body, or normal suspension lift.
Tapatalk'in
02hairlessram
The grill and bumper are nice but the headlights....not so much.
Sent from my Samsung Galaxy Note.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
more info on the heads
The 2013 Ram 1500 quad headlamp design has improved light spread, pattern consistency, distance and 30 percent more lumens. An all-new premium headlamp lighting system is a bi-functional halogen projector design with 15 amber LEDs for park/turn/position lamp and three amber LEDs for the side marker
