RamCares
I think there is an issue in the torque converter related to the solenoid that locks out the torque converter in 8th gear. I am getting excessive heat in the transmission without any load or towing and driving on flat ground. The truck is at the 3rd dealer right now. The previous dealers said to me and I quote, "no code, too bad for you! We wont do anything!"
When I get on the interstate, the transmission temperature will stop at 192 for about 5 minutes, then climb to around 245 in about 15 minutes. As soon as i get off the interstate on side roads, temp drops to 190 and doesn't budge, until i get back on the interstate, then its back to 245!
My fuel mileage has dropped from 24 mpg on the interstate to 16 mpg.
Tell that to the dealer and they say "WOW, never seen that before" or "are you getting an engine code? NO? Awe, that's too bad"
I have deleted the shutters and it hasn't changed the cooling.
Hi Hairy,
I'm sorry to hear about your experience. Has your dealership offered to go on a test drive or look in to the mileage issue for you?
Kori
Ram Social Care Specialist
