2016 1500 EcoDiesel 8 Speed Transmission T-Case stuck in neutral
ctdlaramie15
I don't think this problem was posted yet , my father drove the truck today and everything was fine, upon stoping and putting in park and going into the house for 20-30 minutes, when he came out to drive the truck, a message came up and said 4wd service and the light in the bottem left corner of the gauge cluster Sayed on. Tried shifting the T-Case in neutral and now it won't go into gear at all and will not move. Anyone have this problem yet? Already tried the steps in the manual and no luck.
bhonshell37
Washington
Have you looked under the truck at the transfer case to make sure the linkage is intact?
C
ctdlaramie15
Yes I did, everything looks okay
bhonshell37
Washington
The transmission will shift right? All the fuses and relays are good?
C
ctdlaramie15
The transmission will shift through PRND but won't engage any gears and when placing back in park, P blinks and the cluster says speed to high to complete shift
clh1220
st Louis
You could disconnect the battery. And try it.
6.7CumminsDrvr
The Dude abides………
Georgia
If that doesn't work, check your manual regarding shifting the tcase into neutral, IIRC there is a specific sequence.
I'm gonna see if I can find it
C
ctdlaramie15
Found it in my book, followed the steps exactly as listed and no go,
6.7CumminsDrvr
The Dude abides………
Georgia
Sorry buddy. Just spitballing but maybe you could try using to neutral override process for the tranny.............not sure what would happen but might work to "jog" everything if something quirky is "hanging" everything up.
I'm sure while reading thru the manual you came across the section detailing pulling the strap
C
ctdlaramie15
Yea I did man no luck tried pretty much everything, know how to reset service 4wd light or does it have to be flashed?
freefallin
Is it actually in neutral; will the truck itself move?
C
ctdlaramie15
The T-case is in neutral not the gear selector and yes even in park reverse neutral and drive it will roll
6.7CumminsDrvr
The Dude abides………
Georgia
Well, if the battery reset didn't work you could try a programmer (I think you can still use the code reader function but not sure). If none of that works you might be "up the creek"
Some codes are "hard" codes so a trip to the dealer may be enivitable.
C
ctdlaramie15
Think that's whats going to have to happen...
6.7CumminsDrvr
The Dude abides………
Georgia
Hate it for ya man. Maybe someone else will chime in and save the day
6.7CumminsDrvr
The Dude abides………
Georgia
One last idea..........maybe try disconnecting the electrical harness on the tcase? Should be on the driver side from what I've seen.
C
ctdlaramie15
Haha tried that as well, looked like it might of been a glimmer of hope but it popped back in neutral again, should I try it while the key is in on position
6.7CumminsDrvr
The Dude abides………
Georgia
Well damn..........I would think to try it while the key is off. Did you leave it unplugged and then try shifting?
Sounds like you've tried about everything I would have........
1Popeye
