4th Gen 32 Gal Fuel Tank Swap Questions
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Mine has never done this. My wife had a 2005 Durango she bought new and after a couple years it would. If you let the pump run full force it would blow gas back out like it was under a lot of pressure, and go everywhere. I was getting gas next to a woman filling up her Durango once and it did the same thing.
My Durango did that too those were recalled and I was able to get mine replaced that way way back when although mine technically was not part of the recall.
averageguy
Belleville Mi
hemi
We just lived with it until we sold it and bought a 2014 Journey. It goes in tomorrow for at least the second recall and to see about the screaming sound it makes when it starts during really cold weather.
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I am guessing it has the 3.6L pentastar? Completely normal our 2014 Town and Country does it and so does my parents 2014 Grand Caravan.
huntergreen
my wrangler doesnt screetch on start up.
averageguy
Belleville Mi
hemi
From what I've read it is common with the V-6 but it can't hurt to have it on paper in case something blows apart later.
billyw
Northwest
My '15 1500 5.7 does it too. :(
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
The vans have a pulley they can replace to correct the problem. FCA says it is not an issue but annoying. I had my wife’s van fixed. I didn’t have my moms fixed. I don’t know if it is on other pentastars not in the vans.
BTD07
Texas
2017 Laramie
Thanks for the info on this mod. I drive 1000 miles a week to and from work and have been looking to reduce my stops.
Sent from my SM-N900V using Tapatalk
You need to move! I couldn't imagine that commute!
Edit; Just saw how old that post was aha
jwperry
Polk County, FL
2017 Laramie Crew Cab
I have a similar commute and have been thinking of doing this mod.
The 3 hours a day in the car is the only quiet that I get. :)
Raffgard
Los Angeles
I guess I'll be bring this post back once again. I just picked up a 2016 Ram 1500 Rebel, and have been doing research on this topic. I wanted to see if you also need to replace the sending unit aswell. If so do you happen to have the part number for that. The part number the tank I found was 68242021AC. Lastly, did you have to take your truck it to get the computer reprogrammed for the new gear?
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You just swap the tank the fuel pump and everything else is the same. The gauge will read correct however there have been many complaints that the tank is not even close to empty when the gauge says it is. I think something like 6 gallons remain when the gauge says empty. Basically too much reserve built in.
When you do gears they don’t mess with the speedo. Only changing tire size will mess with speedo. So if you regear you don’t need to do a thing with the speedo to have it be accurate. If you go to say a 34 or 35 inch tire that will need to be adjusted if you want accurate speedo.
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Raffgard
Los Angeles
I forgot to mention, the reason why I'm asking is because my local Ram dealership want $1670 before taxes to do the swap.
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
It is an easy job.
QwikKota
5.7L
FYI, if you have remote start upgrading to the larger tank will frustrate you as the sending unit does not know you have more fuel. My auto start will kill the engine when the low fuel light is on even though I have 6 gallons left. It is also slightly unnerving to drive long distances on the highway with the low fuel light on for 80 miles or so even though you know you will be fine. There is a fix for newer trucks but not 2017 and older I don't believe.
Sent from my VS987 using Tapatalk
smiley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
That is the known issue I was referring to. Dumb huh?
QwikKota
5.7L
****** me off because I love the remote start. If my truck is sitting in the sun in July it's awful inside here in Houston. If it would just not start I'd be more ok with it. Starting and shutting down right away is not good for the engine.
