8 speed question....since it's 100% electronic in cab...
mesaboogie
5.7L
I recently got my 13 Hemi with the 8 speed. I am coming from a 4.7 that was manual stick, transfer, windows and locks, so I have a question as the automatic wasn't my first choice, it was my only choice....
So say my battery dies. Fully dead. Parasitic drain from whatever... (Actually I have even tried putting it in gear on the accessories spot, but I will have to)
What happens if I need to get the pickup in neutral for whatever reason to push it? Is this a case of strap it up and drag it? Did they hide anything under the body other than yanking the driveshafts?
jsl6v8
Virginia Beach for the moment
2013 Ram 1500 HFE RCSB
3.6L V6 And proud.
I'd go with, pull the battery and take it to the autozone and have them recharge it, seems a bit easier than strapping and dragging. But even still I'd think you'd be able to still put it in neutral, every automatic I've had before you can put in neutral even with the car off, but hopefully someone will chime in on whether the Ram will let ya.
20hemi10
SC
5.7L HEMI
On the 8 speed equipped trucks, right above your emergency brake release handle is a cover the hides the release cable for shifting into neutral if you we to ever have a dead battery or if the shifter malfunctions.
Statcher1
Kentucky
Subscribed. Just to hear how this would work out. If you can't get a new battery or boosted.
20hemi10
SC
5.7L HEMI
[/IMG]
Statcher1
Kentucky
Ah I knew there would have to be a fail safe
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Nice info and picture included!
$miley
20hemi10
SC
5.7L HEMI
No problem, just one of the perks of working at a Ram dealership!!
toofart
QC Canada
Hemi 8 spd
Yank the key from the fob, unlock driver door, pop hood, hook up battery pack and/or booster cables, shift to neutral.
I like the info about the lever above the park brake. Great info.
VLG6963
