dan rolfe
- Nov 15, 2016
- 2
- 0
- 2011
- Hemi 5.7
This past winter I purchased a 2011 Ram 2500 Laramie (hemi). Well my normal commute is about 6 miles so I really don't drive all that much. However, the weather here in Virginia has finally gotten hot. My wife and I went on vacation this past weekend and took the truck. About an hour and a half the ac stopped blowing cold air, or should I say it was not blowing very hard. I can hear the fan working like it always does but the air just doesn't seem to be blowing as cold or as hard. We stopped to get something to eat and got back in and exact same thing. AC worked perfectly for about an hour to an hour and a half and then same results. On the way home the exact same issue. This time I just turned the fan off for a bit. About an hour later checked it and it blew ice cold air. I pulled the fan motor out and everything seems normal, nothing loose. I reached up into the ducts and did not fell anything dangling or blocking any of passages. Any suggestions on what to check next? Thank you in advance.
Dan
Dan
